Go to Post Ship day is a sweet and sour day. You're happy to see your robot ship, but then you start going through robot withdrawl - Schneidie [more]
Unread 09-01-2009, 16:22
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
can you use ifi traction material under <R05>
<R05>
All points and corners
that would be commonly expected to contact a GAME PIECE should have a minimum radius
of 0.125 inches to avoid becoming a snag/puncture hazard. All edges that would be
commonly expected to contact a GAME PIECE should have a minimum radius of 0.030
inches. All of these potential hazards will be carefully inspected.
does this rule outlaw the use of ifi traction material.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 09-01-2009, 16:34
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: can you use ifi traction material under <R05>
For a manipulator or something else you probably can. I don't see any reason you can't.
However, if you want it for wheels as I suspect, no. You can't use anything other then the tires they provide for the wheels.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 09-01-2009, 16:50
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Interesting point. It seems to me by that definition it would be illegal, however the rule says "should" not "must." I would argue that anything is legal because of this point, so long as it does not violate any other rules. This needs an official Q/A response though.
Unread 09-01-2009, 16:56
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
A simple clarification that hard or rigid edges or points may not regularly touch the game piece would resolve this beyond all doubt.
Until then, we could examine the intent of the rule. The intent of the rule is that we don't damage the game pieces, as noted by "to avoid becoming a snag/puncture hazard". Since IFI wheel tread points are 'soft' and do not snag or puncture (aka damage) the balls, one would think that the rule already answers the OP's question.
GitHub
How close can you mount the IFI Controller to a CIM motor Capt. Quirk Control System 8 20-02-2008 19:37
Can you use this? Mars Control System 7 23-01-2008 08:24
IFI traction wheels rachal Technical Discussion 10 17-04-2007 22:01
IFI Traction Wheels chris31 Technical Discussion 4 23-12-2006 09:25
Despite what IFI says, you can configure autonomous from OI... TedP Programming 19 31-03-2004 10:09
