Go to Post Sometimes, having someone that can teach you just shows you another way to do what you've been doing, but in fewer moves. - Amanda Morrison [more]
Unread 09-01-2009, 17:21
xrabohrok's Avatar
xrabohrok xrabohrok is offline
hunter of errors
FRC #1208 (The Metool Brigade)
xrabohrok is an unknown quantity at this point
Failure to launch: nothing happens in tethered benchtop test
Our team has finally wired the power to the control system and we started doing a bench test. We have everything hooked up (to the best of our knowledge) and everything blinks all nice and happy. When we tether the robot to the bench, nothing happens. Jaguar lights continue blinking yellow, and we even hooked a motor to one, and it doesn't respond. The ethernet ports flash orange and green, so something is going on, but not what the benchtop test specifies.
Details:
Driver station:
2 joysticks, usb ports 1+2
tether in eth port 1
running *OTB* version
Robot Controller:
1 Digital sidecar plugged into NI 9403 bus in the center of bridge
jaguars using PWM cabes plugged into PWM OUT +V 1-4
jaguars jumpered OTB setting
attempting benchtest Rev .4
Do I need to update the firmware? Is there an updated version of the bench test? If there is, can someone post links?
"It's programming's fault" may be a viable excuse for just about everything, except the robot falling apart.
It will 'cause it can!
constants aren't. variables won't.
Unread 09-01-2009, 17:28
Re: Failure to launch: nothing happens in tethered benchtop test
You didn't say, so I have to ask: does the Digital Sidecar have power connected?
Also, what does "bus in the center of bridge" mean?
You should hold off updating the firmware for now. Leave the DS and cRIO in their Out-of-The-Box state until you resolve why you're not getting a valid PWM signal to the Jaguars.
Unread 09-01-2009, 17:36
xrabohrok's Avatar
hunter of errors
The Sidecar lights up (green lights) when we flip the breaker, I guess so.
The cRIO has 8 slots, the NI 9403 piece is plugged into slot 4 (from the ethernet ports).
Thanks for the quick response.
Unread 10-01-2009, 11:23
xrabohrok's Avatar
hunter of errors
We figured it out. The PWM's were plugged in backwards. Oops.
Thanks for the help!
Failed Benchtop test rhoads2234 Programming 22 10-01-2009 10:49
"Benchtop Test" Help! tiger192 Technical Discussion 5 07-01-2009 16:45
New Ctrl Sys Early Ship - Benchtop Test rrossbach FRC Control System 37 19-12-2008 00:40
Robot Test - Failure Fixen Rumor Mill 34 07-02-2005 23:20
Second test launch of newsletter! Ken Leung CD Forum Support 3 19-10-2001 04:29
