Go to Post Dash Board: Hey Robot, here is some new data. Dash Board: Robot, did you get that data yet? Hello? Robot: Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks!... Other Robots: Will you please shut up? - EricVanWyk [more]
Unread 08-01-2009, 22:11
Delia's Avatar
Delia Delia is offline
FRC #1712 (Dawgma)
Delia is a splendid one to beholdDelia is a splendid one to beholdDelia is a splendid one to beholdDelia is a splendid one to beholdDelia is a splendid one to beholdDelia is a splendid one to beholdDelia is a splendid one to behold
Send a message via AIM to Delia
Re: Failed Benchtop test
Hey Erin you should see if you guys can come to LM this saturday, our Lockheed guys can help you out.
Facebook me about it.
:: Delia ::
:: 2010 Dean's List Winner::
:: FRC 1712 Almuni::
Unread 09-01-2009, 16:00
Christine2234 Christine2234 is offline
FRC #2234
Christine2234 is an unknown quantity at this point
Originally Posted by Alan Anderson View Post
Crossover cable? You should only use that to connect the camera to the cRIO's second ethernet port. All the other ethernet cables you use should be standard straight-through connections.
We've tried with straight up Ethernet cables, too, and still nothing.
We're located in Newtown Square, and I think that's around 2 hours from where 103 is...we might try calling an NI engineer and asking if it's a problem with the cRIO itself.
Unread 09-01-2009, 16:12
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Please go ahead and contact NI through ni.com/first.
Unread 09-01-2009, 17:05
awizkid awizkid is offline
JoJo
FRC #2063
awizkid is an unknown quantity at this point
Send a message via AIM to awizkid
did you use the victors, that you are ussing, in prevouis years. The last 2 years we had to reset the victors before they would work for us. To reset:
(1)make sure all power is off, so either diconnect the battery or manualy trip the main circuit breaker.
(2) ther is a little hole on the victors, there is a little switch inside. get something small that can fit in the hole.
(3) hold the switch down, and while still holding it down, turn on the power. the victor light should be a solid color.
(4)keep holding down the button in tell it starts flashing.
(5)to test if it worked: turn on and connect the driver station and the light on the victor should be a solid yellow when everything else is set up right.
PS: make susre you have the pwm cables pluged in the rght direction. The white part of the cable should be plugged into the signal side of the port.
Unread 09-01-2009, 17:34
GregW11's Avatar
GregW11 GregW11 is offline
Mad-haired biker man
FRC #2261 (Casa MESA)
GregW11 is on a distinguished road
Send a message via AIM to GregW11 Send a message via MSN to GregW11
Here's a random thought: make sure only ONE of the serial-like cables (going from the cRIO to the power distribution) is connected to the cRIO. I had similar problems but when that was disconnected it worked perfectly fine. Obviously make sure the one connected is going to the power distribution that has the wire in it (hooked up in the first signal slot)
Unread 09-01-2009, 18:42
rhoads2234's Avatar
rhoads2234 rhoads2234 is offline
AKA: Erin
FRC #2234
rhoads2234 will become famous soon enough
Thank you to everyone who posted a suggestion.
We got it to work at last by setting the IP address. (I will get the teammate who did it to post a more detailed discription)
Good luck with the rest of build season!!
ALWAYS a mechanical problem!
Unread 09-01-2009, 22:45
The only connection from the cRIO to the Power Distribution is the 24 volt power (plus 12 volts to each of the Solenoid and Analog Breakouts).
Do you mean the 39-pin cable used to connect a cRIO 9403 digital I/O module to a Digital Sidecar?
Unread 10-01-2009, 10:49
FRC #2234
Thanks for everyone's help! We've finally figured it out; we had to set the IP address of our Ethernet port on the laptop and then Image the cRIO to set the IP on the cRIO itself. For anyone else who has this problem, what we did was:
1. Disable all other connections (internet, etc)
2. Start -> Control Panel -> Network Connections
3. Doubleclick Local Area Connections
4. Click Properties
5. Scroll Down in the windown and double click Internet Protocol (TCP/IP)
6. Click Use the following IP address and set the IP Address to 10.xx.yy.6 where xxyy is your team number
7. Set the Subnet Mask to 255.0.0.0 and click OK
8. Open up the FRC cRIO Imaging Tool and check Format Controller
9. Set the Team ID to your Team number (xxyy)
10. Let it image - this should take a while
"Benchtop Test" Help! tiger192 Technical Discussion 5 07-01-2009 16:45
New Ctrl Sys Early Ship - Benchtop Test rrossbach FRC Control System 37 19-12-2008 00:40
Smithy or other Benchtop Mills/Lathes/CNC Dan Richardson Technical Discussion 6 21-06-2007 22:32
Compiling Failed Teh Mike Programming 7 09-02-2005 13:27
