Go to Post However, it is logistically impossible, so it's now just a joke. - EricH [more]
Unread 09-01-2009, 17:58
Pneumaticsman's Avatar
Pneumaticsman Pneumaticsman is offline
AKA: Mitch guzman
FRC #1566 (Ammoknights)
Pneumaticsman will become famous soon enoughPneumaticsman will become famous soon enough
Send a message via MSN to Pneumaticsman
Question cRIO Problem
Ok, I'm sure this question has been asked multiple times on other forum threads, but my patience grows thin so I will just go ahead and state my error. In LabView when we try to deploy a project to the controller, LabView says that it has failed to connect to a real-time connected to a real-time target. We have the correct ip address assigned to the controller but it won't connect, the battery is good but the status light is yellow. could that be part of our problem? Please help us as this is going to be extremely important to have a working robot this year
Thanks
be prepared for the unexpected
Unread 09-01-2009, 18:11
WGRAY WGRAY is offline
FRC #2027
WGRAY is an unknown quantity at this point
Re: cRIO Problem
Please download this great little tool (thanks Team 1629) http://www.chiefdelphi.com/forums/sh...ghlight=pinger
It will give you the status of your pc,router, DS, bridge and crio. Then you can tell if your problem is software or hardware.
Unread 09-01-2009, 18:39
AKA: Mitch guzman
Re: cRIO Problem
...I love you haha thanks
Unread 09-01-2009, 18:53
AKA: Mitch guzman
Re: cRIO Problem
ok so we have connection with everything except for the bridge and the cRIO. does this mean we may have to re-update the cRIO or something?
Unread 09-01-2009, 19:08
mahmosh's Avatar
mahmosh mahmosh is offline
FRC #1946
mahmosh is an unknown quantity at this point
Re: cRIO Problem
to solve this problem ... upgrade the crio by FRC cRIO Imaging Tool
then try to deploy the project again ...
Unread 09-01-2009, 19:28
Jlulian Jlulian is offline
AKA: Julian Moore
FRC #0004
Jlulian is an unknown quantity at this point
Re: cRIO Problem
It sounds more like your bridge isn't connecting to the router. (Connect directly to it and configure it to connect to the router)
Unread 10-01-2009, 11:10
Marlfox's Avatar
Marlfox Marlfox is offline
Team Role: Electrical
Marlfox is an unknown quantity at this point
Re: cRIO Problem
How do you configure the router?
You're about to be struck by a vehicle!
Unread 10-01-2009, 11:39
AKA: Mitch guzman
Re: cRIO Problem
nevermind we got it working
Unread 10-01-2009, 11:59
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: cRIO Problem
For all of your getting started configuration needs, please consult the following documents at USFIRST.ORG. The first is the official launchpad with "every" link. You'll definitely need to go through the first 5 chapters in sequence (painful but critical). The other two links are for LabVIEW training (and were obtained from the launchpad site).
http://www.usfirst.org/community/frc....aspx?id=10934
http://decibel.ni.com/content/docs/DOC-2631
http://decibel.ni.com/content/docs/DOC-2663
Russ
CRIO Error 60 seanl FRC Control System 14 18-01-2009 16:29
cRIO fuse??? 20 or 30? mynameisbob Electrical 12 09-01-2009 11:33
cRIO feedback Maxpower57 C/C++ 2 08-01-2009 19:06
cRIO plugin problem gabrielse National Instruments LabVIEW and Data Acquisition 3 18-12-2008 11:30
cRIO test drive *OFB* problem.... NetSkay FRC Control System 5 10-12-2008 18:32
