Go to Post FIRST is a worthwhile program to be involved in as an Adult mentor. But for me, it does bring its share of personal conflict. ..... Cuz' you know when Jan 4/5 comes round' I'll be itchin to go gang busters again. I'll never learn - PMGRACER [more]
Unread 09-01-2009, 18:38
Re: Team Update #2
Originally Posted by Greg Needel View Post
I had this exact same thought and I asked it on the Q&A. It seems to me that these 2 are contradictory.
I also wonder the same as Jgannon why they are addressing specific robot designs in the rules. It is really starting to make me wonder why they just didn't include an instruction manual with the kit this year saying "we want you to build this"
Or like "You really shouldn't build something like this..."
Idk man....I'm not liking this very much still =/
But, I'm still open to changes.
Unread 09-01-2009, 19:06
President, VEX Robotics, Inc.
Re: Team Update #2
The 6" bumper picture doesn't make sense. It clearly states in the rules that a bumper can use a pool noodle vertically oriented at the end or bevel the edges. If you bevel the edges you get 3" of bumper sticking out from the bumper perimiter and this is specifically legal. That leaves 3 more inches required to get 6. What they show is 9" of bumper, not 6" (my 4 year old showed me the math behind that one). Since when did 3 + 6 = 6?
Unread 09-01-2009, 19:09
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Team Update #2
Figure 8-2 is incorrectly drawn, by my interpretation. It shows the red line as the Bumper Perimeter. Then I assume the brown line outside that would be the plywood part of the bumper. If so, it should not be extended along the sides of the robot frame.
Figure 8-2 is illustrating where wood vs noodles go. If you blow it up to about 400% you can see there may be a tiny bit of space in the lower left corner. The wood cannot wrap around the corner - it cannot extend past the end of the frame. (The wood in the lower right corner is shown correctly.) But the noodles can go around the corners, and 8-2 shows a variety of ways that can be done. In fact, it seems to be saying that the noodles must go around the corner, as the upper right corner is marked "Not OK". Noodles may go around the corner as a mitered corner (lower right), butted up against each other (upper left), or bent and enclosed in one piece of cloth (lower left).
This update does not confirm or refute that each face side of a robot must have a bumper. There was an earlier related posting of a robot with a wide opening, no bumper on that side, and the foam extending beyond the end of the edge to protect the corner. Both of those issues still have to be asked in Q&A.
(since 2004)
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Re: Team Update #2
Alright, that makes more sense.
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 09-01-2009, 19:11
Re: Team Update #2
I edited the original post. I guess my brain wouldn't let me put 3 + 6 = 6 ...
Unread 09-01-2009, 19:13
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Team Update #2
Paul, my interpretation is that a bumper segment includes the backing board, which must be at least 6" and must be attached to the frame. Noodles can extend farther than that 6", but not less.
(since 2004)
Unread 09-01-2009, 19:22
Re: Team Update #2
Yep Gary, you are right. Rule R8 sub part J makes this painfully obvious. Oh well.
Unread 09-01-2009, 19:34
REVving up for a new season
FRC #2848 (All-sparks)
Re: Team Update #2
it still isn't clear to me how the length is accounted for. I understand about the over hang and that what they are showing is 2 sections of bumper with the smallest being 6 inches, but what happens if you make a single bumper that wraps the corner as in 8-2 lower left. While the wooden joints can't over lap, I would argue that, the example shown is 1 bumper and not 2, which is definitely more then 6 inches.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 09-01-2009, 20:33
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Team Update #2
We have to include the definition of a BUMPER into the updates to get the full picture -- A BUMPER by definition technically has a plywood backing, therefore it is also considered a 'hard' bumper by other clauses of the rule, which may not overlap in the corners. Hence, teams need 6" of a plywood-backed 'hard' BUMPER coming off of the corner of every side. Not only that, rule <R08-M> states that all BUMPERs must be supported by the robot, without gaps. This means you must have a piece of your robot backing the bumpers in every corner.
Hence, when you put all clauses of <R08> together, their drawing is correct and makes sense. We've had to rearrange the frame in some way or another over 8 or so drive train iterations to get it right to comply with the bumper rules . Next year the bumpers need their own section, lol.
<edit> Of course, as I write this I notice clause <E> that states BUMPERS must not weigh more than 18 lbs, so by what I just said the vertical pool noodles shouldn't count towards the weight of the bumpers. But common sense tells us that the vertical noodles are apart of the bumpers... So eh, perhaps they could re-word it to state that the minimum length of 'hard' bumpers must be 6".
2017 Scoring Model
CAD Library | GitHub
Unread 09-01-2009, 20:44
Hanna2325's Avatar
Hanna2325 Hanna2325 is offline
Programmer/Driver
AKA: Hannah
FRC #2177 (Robettes)
Team Role: Driver
Hanna2325 will become famous soon enoughHanna2325 will become famous soon enough
Send a message via AIM to Hanna2325
Re: Team Update #2
ha ha...ya i agree
Unread 09-01-2009, 21:09
BenB's Avatar
BenB BenB is offline
AKA: Ben Bennett
FRC #1114 (Simbotics)
BenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond repute
Re: Team Update #2
Is the intent of this update to warn us for damage to our robot or the risk of penalty for contacting an oppositions trailer in this fashion?
2010-present - Team 1114 - Simbotics
2007-2009 -Team 2166 - Bluebotics
JesseK's Avatar
FRC #1885 (ILITE)
Re: Team Update #2
Originally Posted by Kyler View Post
Well... what if your robot looked something like this?
Sorry about the paint image but if black is the robot's outline and purple is bumpers it would be possible to curve plywood around that curve on the front i believe and it would still satisfy the current rules. Please correct me if I am wrong.
Let's just hope that curved parts don't count as technical corners...then we'll see a whole slew of definitions for a CORNER and all of its ensuing confusion.
Since curves are not edges, I would presume that your drawing is ok for the front of the robot:
Rule <R08-O>
The BUMPER backing must not extend beyond the “edge” of the ROBOT. The backing of
adjacent BUMPER segments must not attach to each other if the attachment would require
that the joint extend into the corner (see Figure 8 – 4).
2017 Scoring Model
Unread 09-01-2009, 21:27
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Re: Team Update #2
I'd like to think that an inspector, looking at a curvy bumper that is made well, will pass it. A well made curvy bumper (IMO) would have notched wood and notched angle stock to meet the profile as shown in the figure. If you notch it and form it well, it should meet the "intent" of the rule.
... but ... My team's not going curvy, so I'm very interested in the interpretation of the hard surfaces versus the "vertical" piece of floaty.
I could see that if there were 2 floppy piece-parts, backed with 2 separate boards, and only held together by the cloth and the vertical piece, then both of those pieces should be required to be 6" in length.
But, if my hard-parts were formed together as one piece, and rounded the corner as one rigid unit, with or without the vertical piece (i.e. cut angles in the floaties for an angled joint), then I can count the internal linear distance of the angled piece.
So an L-shaped bumper with 4 + 2 inches of coverage would satisfy the 6" rule ... as long as it's a rigid one-piece bumper.
Assuming I'm right, now they'll have to define what "protecting a corner" means. Minimum 1" of bumper? 2"? 3"?
[edit] if they say 6" is the minimum, then they'll also have to revise figure 8-2.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Last edited by Ziaholic : 09-01-2009 at 21:31. Reason: ... oh yea ... one more thing ...
Unread 09-01-2009, 21:32
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Team Update #2
So is the consensus that this rule is saying that we must have two 6" pieces of bumper on the front or could it be less as long as it wraps around. If it is saying that we must have a certain amount of bumper isn't this getting a bit ridiculous how much regulation there is in the design. Where is the room for innovation?
Mentor 2415
Unread 09-01-2009, 21:53
Ziaholic's Avatar
Elec/SW Mentor
AKA: Marc
Re: Team Update #2
... and another thing ... they should give us the 7" trailer hitch linear distance as a gimme. There are not many physical ways to poke into that area, so they should let us include that 7" linear distance as a part of our 2/3rds requirement.
Team Update 17 ntroup General Forum 33 14-03-2007 16:58
Team Update # 11 Bcahn836 Rumor Mill 6 21-02-2004 07:33
Team Update #3 dez250 General Forum 4 21-01-2004 11:56
Team Update 5 archiver 2001 4 23-06-2002 23:36
