Go to Post "Dress to impress," typically, means no denim (sorry, Dean)... - Madison [more]
Unread 09-01-2009, 20:35
Mike Wittman's Avatar
Mike Wittman Mike Wittman is offline
Plastic Man
FRC #1714 (More Robotics)
Mike Wittman is an unknown quantity at this point
Re: Wireless Connection Problem
We were a beta test team. We had this problem with the beta equipment and with our FIRST equipment. The simple answer is after you set up your network ip addresses power cycle everything in order. I don't know why but sometimes the IP address doesn't take until you power cycle the router and bridge.
This is the power cycle order
1 Router
2 Driver station (wait until it boots up) then go to step 3
3 cRIO
4 power up the wireless bridge
If powercycling doesn't work it is far quicker to reset the router and bridge back to factory default and start over rather than to try to figure out where you went awry. When you reset to factory default use the included disks do not do it from the web.
Mike
Tie two birds together, though they have four wings they cannot fly
www.morerobotics.org
Learn More, Give More, Be More
Wireless problem - losing communication jalburty FRC Control System 9 09-01-2009 07:35
Wireless Programming FRC4ME Programming 14 14-04-2008 00:22
problem with connection seanl Programming 1 29-01-2007 10:41
USB DAQ Wireless connection? StevenB National Instruments LabVIEW and Data Acquisition 1 01-01-2006 03:49
Wireless Connection on Pocket PC - AEGIS and Odyssey sanddrag IT / Communications 2 07-01-2005 15:51
