Go to Post The most important part anyone can lend is just a hand. - Libby K [more]
Unread 11-12-2008, 19:09
Mac Generals Mac Generals is offline
Tony-Team 1358 Advisor
FRC #1358 (Generals)
Mac Generals is an unknown quantity at this point
Basic wireless question
A very basic question. We are bench testing, all went well until going wireless. Are we supposed to instal the router and gaming adapter software provided with them in order to configure them??
Unread 11-12-2008, 22:42
Re: Basic wireless question
NO.
Do not install the provided software on your computer. You will be configuring the hardware manually using a web browser.
Unread 11-12-2008, 22:43
You don't need to.
The most common issue seems to be using the same security settings on both the router and the bridge. The manual fails to cover that and it can trap you.
Unread 11-12-2008, 23:11
We have had trouble logging onto the web browser-any hints or suggestions as to the proper procedure?
Unread 12-12-2008, 09:31
Connect directly to the device you are trying to reach with a regular straight-through ethernet cable.
Set your PC IP address to match the device. That'll be different IP's at different steps in the setup process. Your original PC IP address should work if the router or bridge hasn't been touched yet, or set your PC to 10.13.58.6 if you've gotten past the set that changes the router or bridge IP's to 10.13.58.x
Type these addresses into your web browse:
Bridge--
--http://192.168.1.250 with your default PC IP address
or
--http://10.13.58.1 with your PC set to 10.13.58.6
Router--
--http://192.168.1.1 with your default PC IP address
or
--http://10.13.58.4 with your PC set to 10.13.58.6
You can reset the router and the bridge with a paperclip in a small hole in the back labeled "Reset" to get them back to the default IP addresses.
It'll also reset the default user names and passwords in case something got mistyped. All the settings in the manual will have to be redone.
If all else fails bring the equipment to tomorrow's workshop.
Unread 18-12-2008, 09:16
Teammax's Avatar
Teammax Teammax is offline
30 Members 6 Weeks 1 Dream
AKA: Rob Cormier
FRC #1071 (Team MAX)
Teammax is just really niceTeammax is just really niceTeammax is just really niceTeammax is just really nice
Mark McLeod's responce about the security was very helpful to us. Unfortuneatly being a person that is not to computer savvy figuring out what Mark meant and how to fix this problem was still a challenge for me. So let me just go through how we corrected the security issues so that the router does not have a secured signal.
On the pages for the router (blue border) select "wireless"
then select "wireless security"
after this select go to the security mode choices and select "disabled"
then at the bottom "save settings"
Unread 18-12-2008, 09:29
Just a followup.
Mac Generals problems were traced to the school issue laptop they were attempting to use. They are properly setup now.
Thanks Rob, for the details on fixing the security.
Unread 09-01-2009, 22:14
pollyproof12 pollyproof12 is offline
AKA: Jarrett
FRC #1865
pollyproof12 is an unknown quantity at this point
i have already installed the software for the router. is that really a problem?
Programmer
Unread 09-01-2009, 22:31
In that case you should reset your router/bridge and step through the instructions given in the control system manual.
Basic Question Wompas Programming 4 20-01-2007 14:33
Basic Stamp Replacement Question Nate Smith Programming 4 13-07-2005 01:13
Probably a basic question, but.... Raven_Writer Programming 7 17-01-2004 01:04
Very Basic Programming Question kewlkid382 Chit-Chat 5 18-01-2003 11:11
Question about Basic Stamp miketwalker Programming 3 14-01-2002 13:10
