Go to Post Real projects have good and bad aspects, problems that must be dealt with, and lots of things that dont make any sense from your side of the fence. - KenWittlief [more]
  #76   Spotlight this post!
Unread 09-01-2009, 23:46
krupinski krupinski is offline
Team Captain
AKA: kyle
FRC #0204 (Eastern Robotic Vikings)
krupinski is an unknown quantity at this point
Re: Implementing Traction Control for an advantage in the 2009 game
I'm not sure who said it but i know some one mentioned before about using an accelerometer to sense drift and turn the wheels perpendicular to the direction of unwanted travel... my team also had a similar idea but threw it out ( for now) due to the fact that this will only make a difference if the deflection of the floor is a [i]relatively[i] significant amount.. We started to reconsider when we found the regolith is over the carpet (or so we've heard) but are still unsure if it will have any useful effect.. if the floor doesn't deflect enough you get the same effect by just locking the wheels, or are we misunderstanding this concept?
"just cause im the captain dosent mean i have all the answers!!!" - me
"Should the brain be smoking?"
"There are 10 types of people in this world, those who know binary and those who don't.."
Mountain Dew = Success!
  #77   Spotlight this post!
Unread 10-01-2009, 09:52
RandomStyuff RandomStyuff is offline
FRC #2212 (Spikes)
RandomStyuff is a jewel in the roughRandomStyuff is a jewel in the roughRandomStyuff is a jewel in the roughRandomStyuff is a jewel in the rough
If there is a project for trying to implement a common code base for the base of this an ABS-system-like idea, my team has a couple of programmers who would be willing to help... it could really be an interesting project to implement it together in a codebase for everyone
  #78   Spotlight this post!
Unread 19-01-2009, 22:02
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Wow, what a thread. Wish I understood what half of it meant, although I did get a chance to learn the first, second, third derivatives of wheel positon are velocity, acceleration, and jerk.
We just started working on this today. We use a potentiometer to measure the rate the wheels are turning. If we see an increase of > 20% in the rate, we reduce the power to the wheels by 20%. Power keeps reducing until the rotational rate gets back below 20%.
May not be absolutely perfect, but we will hopefully get enough of an advantage to beat the teams that don't have traction control.
Unfortunately I think this puts us in the 'tinkerer' category isn't the second first derivative of tinkerer = engineer once you add in the velocity heading towards being able to calculate the results?
  #79   Spotlight this post!
Unread 20-01-2009, 07:02
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Tinkerer + math => engineer
  #80   Spotlight this post!
Unread 20-01-2009, 07:07
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
We're going with a reverse-ABS route for our first attempt:
-If slippage detected, reduce motor power somewhat, then gradually increase it again
Slippage will be detected by comparing the reported acceleration of our encoders with the reported acceleration from our accelerometer.
  #81   Spotlight this post!
Unread 20-01-2009, 08:40
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
For the Tinkerers out there. Please keep one thing in mind. ABS, ESP, Stability control..... All of these get tuned by very skilled evaluator/engineers. I have a friend who does this work for Bosch. Testing and tuning is not simply tinkering, it is engineering. They do however had a pretty good idea of what their algoritms need to look like and then tune them in.
IKE
  #82   Spotlight this post!
Unread 20-01-2009, 19:21
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
This is the only field where being a tinkerer will mean that your robot will end up in twenty thousand little itty bitty pieces as it thrashes it around because your tinkering resulted in a system that mathematically would blow up the world (An Texas Instruments engineers words not mine) if it were not for the fact that your robot is powered by a battery.
  #83   Spotlight this post!
Unread 21-01-2009, 22:16
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Our programmer challenged our 2 year driver to try and beat the traction controlled robot from one side of our field to the other.
The driver lost EVERY time!!
In conclusion, implement it if you can........
  #84   Spotlight this post!
Unread 21-01-2009, 23:19
DonRotolo's Avatar
Back to humble
FRC #0832
A potentiometer? Not exactly an optimal sensor, look up "encoder" for a better choice
first derivative of tinkerer = engineer once you add in the velocity heading towards...
The difference between a Tinkerer and an Engineer is that the Engineer will be able to tell you the results before you start.
  #85   Spotlight this post!
Unread 22-01-2009, 12:03
agmlego's Avatar
agmlego agmlego is offline
Jack-of-all-trades
AKA: Andrew Meyer
FRC #0857 (Superior Roboworks)
agmlego is an unknown quantity at this point
Send a message via ICQ to agmlego Send a message via AIM to agmlego Send a message via MSN to agmlego Send a message via Yahoo to agmlego
Our team is looking into implementing an algorithm we found for a four-independent-wheel-drive electric vehicle ETS, using four encoders and a gyroscopic yaw-rate sensor. We will be enhancing it with the accelerometer to detect sideways skid and report to the driver, if not correct it.
"I can guarantee that if it breaks today, it will be something that has never broken before"
--Arthur C. Clarke, The Trigger
  #86   Spotlight this post!
Unread 22-01-2009, 16:25
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Right now Warren B and I are trying to get our arms around Paul's "middle income" solution. But for those of you going for the "super rich" solution, I have found a few interesting places to look:
http://scholar.lib.vt.edu/theses/ava...ed/Thesis2.pdf
and here's some observer and alpha-beta filter explanations:
http://www.mstarlabs.com/control.html
Check out "rough Data, Smooth signals" and "When One feedback isn't enough"
I expect SPAM'll compete with the "middle income" solution at the Florida regional
cool stuff
Eric
Don't PANIC!
S. P. A. M.
  #87   Spotlight this post!
Unread 23-01-2009, 09:08
agmlego's Avatar
Jack-of-all-trades
AKA: Andrew Meyer
Hey, cool! I will definitely have the guys look in on those.
  #88   Spotlight this post!
Unread 23-01-2009, 09:26
Bongle's Avatar
Just a note:
We went to implement our accelerometer/encoder solution last night, and it wasn't as good as expected. This was partly because I hadn't totally thought it through and thought that simply comparing accelerations was going to be sufficient. I failed to realize the obvious fact that the encoder acceleration would not STAY above the accelerometer acceleration for long, so it is not a good way of telling when the wheelspin stopped. It was an excellent way of telling when your wheel started spinning, but since you can't easily detect when they stop spinning, the algorithm as I described it is not ideal.
We're going to have to get a bit more complicated, with either an estimated velocity from the accelerometer or a trailing wheel to get this working properly.
  #89   Spotlight this post!
Unread 23-01-2009, 10:11
Jared Russell's Avatar
Taking a year (mostly) off
You can try integrating the acceleration signal to get velocity, and then comparing velocities to detect slip. The problem is that a noisy accelerometer signal looks even worse once it's integrated. For this and other reasons (one being the simplicity of an apples to apples speed comparison in code), non-driven encoder wheels lead to a better solution to this problem in my opinion.
  #90   Spotlight this post!
Unread 23-01-2009, 10:34
Bongle's Avatar
Yeah, that's exactly what I'm thinking. Even with our rolling-average filtering, the accelerometer is ridiculously noisy.
The 2009 Control System Q&A Thread crake FRC Control System 59 11-01-2009 10:43
Drive train for 2009 game hihihiflcl81pig General Forum 4 27-12-2008 02:17
Buying the 2009 control system BornaE FRC Control System 9 16-10-2008 17:16
The Access Points on the 2009 Control System Shadow503 Rumor Mill 10 28-04-2008 23:22
UNFAIR ADVANTAGE for CDI and new control system archiver 2000 6 23-06-2002 22:13
