Go to Post FIRST is difficult and it is challenging, but you aren’t necessarily required to go off and build an 8 motor drivetrain and 4 motor / 8 pneumatic piston arm mechanism for the heck of it when a 2 motor non-shifting drivetrain and 2 motor arm does just as good a job. - Bill Gold [more]
Unread 09-01-2009, 23:19
Team2883's Avatar
Team2883 Team2883 is offline
FRC #2883
Team2883 will become famous soon enoughTeam2883 will become famous soon enough
Dashboard and Robot main with Axis camera
We have had our robot chassis rolling but when we began to play around with the Axis camera we tried to follow the setup for the camera but when deployed to the crio we recieve the camera image but now we cannot move our robot. All we get is flasing yellow onb the jaguars. Is this an issue with the Robot main code that is from the LAbview Main. I am sure we are missing something but with out an actual programing class or professional as of yet we are trying to explore and troubleshoot issues. Seems like Chief Delphi has alot of answers so if anyone can help thanks a ton.
Unread 09-01-2009, 23:31
WGRAY WGRAY is offline
FRC #2027
WGRAY is an unknown quantity at this point
Re: Dashboard and Robot main with Axis camera
is your robot main deployed?
Unread 09-01-2009, 23:35
FRC #2027
Flashing yellow means its lost its link. Not receiving a signal from you.
Unread 09-01-2009, 23:38
FRC #2027
deploy robot main, click enable vision, let it run then go to view- getting started window-and pull up a dashboard project and run.
Unread 10-01-2009, 00:20
Or it could be as simple as forgetting to flip the switch on the dongle to enable the robot. Or the dongle itself could be unplugged. Or a wire could have broken inside it.
Double-check to make sure the DS screen doesn't show the robot in "disabled" mode.
Unread 10-01-2009, 00:24
Team2883's Avatar
FRC #2883
When we deploy the robot main we get to 36% then it seems to stop we clicked on close and then try to the enable vision and we can see pics from the camera but no movement. Just to get this right I open both of the VI's dashboard and Robot main, then go to run in each this should give us the default arcade control is that correct. I can see how the labview is going to give us alot of options but without getting the default program to load we are lost thanks for help thus far.
team 2883
Unread 10-01-2009, 00:25
Team2883's Avatar
FRC #2883
no our donggle is working it shows up on the DS as enabled and disabled.
Unread 10-01-2009, 00:28
Team2883's Avatar
FRC #2883
could we have an issue that we have the vision screen on robot main? We did not have the dashboard up is that an issue, do we have to have both of them or will it work with just running the robot main.
Unread 10-01-2009, 05:50
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Where's the enable vision button? I only found one reference of it in the Vision Processing.vi, but it's a read and not a write.
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 10-01-2009, 07:35
FRC #2027
On the front panel of robot main, is the enable vision switch
Problems with the Axis Camera popo308 FRC Control System 16 15-01-2009 19:38
AXIS Camera nickmagus Programming 1 03-01-2009 20:06
Program Axis Camera in c++ excel2474 Programming 5 22-12-2008 17:14
Dashboard with analog and dig inputs Andrew Schreiber National Instruments LabVIEW and Data Acquisition 1 13-02-2006 22:48
Emergency Help Needed on Main Board and Camera amateurrobotguy General Forum 9 09-02-2006 21:22
