Go to Post I remember seeing that hair do. It is what inspired me to become an MC one day. - Tetraman [more]
Unread 09-01-2009, 17:14
Magnechu Magnechu is offline
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Team Role: Tactician
Magnechu has a spectacular aura aboutMagnechu has a spectacular aura about
Send a message via AIM to Magnechu
Trailer Hitch Question
What is the diameter of the pin that directly connects the robot and the trailer hitch?
SBPLI Long Island Champions 2003 2005 2006
SBPLI Semi Finalists 2007 2008 (#1 seed) 2009 (#1 seed)
Galileo Finalists 2009 (thanks 1717 and 2775)
Unread 09-01-2009, 17:29
RyanS's Avatar
RyanS RyanS is offline
Team Captain
AKA: Power Driver
RyanS has a spectacular aura aboutRyanS has a spectacular aura about
Re: Trailer Pin Hitch
R18
The Trailer Hitch must be positioned so that the TRAILER may be locked in place with a standard 1/4– inch diameter hitch pin (McMaster-Carr part number 98416A009).
Ryan
2010 Los Angeles Finalists
2010 San Diego Regional Winners
2009 Los Angeles Regional Finalists
2008 San Diego Regional Winners
2008 FTC World Champions
Unread 09-01-2009, 17:33
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Ah, sorry I didn't make myself clear.
Piece 19 in the schematics of the trailer, the Swivel Hitch, that connects the robot and the trailer. How big is that?
Unread 09-01-2009, 17:47
RyanS's Avatar
Team Captain
AKA: Power Driver
I believe the trailer tongue is 3/4" EMT conduit. As for the length, it should be in the drawings.
Ryan
Unread 09-01-2009, 18:02
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Ah, we figured everything out by finally locating the drawing we needed. Thanks a lot
Unread 09-01-2009, 18:19
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Haha new question:
Can you alter the trailer hitch materials provided in the KoP for weight reasons?
Unread 09-01-2009, 19:10
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Originally Posted by Magnechu View Post
Haha new question:
To make it heavier, would give you an unfair advantage.
To make it lighter, would give you no advantage since the weight does not count toward the weight of the robot.
So the question is ... why?
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 09-01-2009, 19:19
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
What we mean is, there are materials in the KoP that the trailer will be connected to (I'm not sure on the correct terms) that must be permanately fastened onto the robot. How would that not count towards the weight of the robot? Will they weigh them separately and then subtract that from our total weight?
We are under the impression that we cannot alter ANY parts regarding the trailer connections, unless we are mistaken with the parts that are permanately on the robot. CAN we use other pieces (altered pieces of equipment, for example) that are to stay on the robot or must we use the unaltered pieces in the KoP?
Unread 09-01-2009, 19:36
Update #1 states"
A. Exception: solely for the purposes of determining compliance with the
weight and volume limitations, these items are NOT considered part of
the ROBOT and are NOT included in the weight and volume assessment:
• The 12V battery and its associated half of the Anderson cable quick
connect/disconnect pair (including no more than 12 inches of cable per
leg, the associated cable lugs, connecting bolts, and insulating
electrical tape),
• BUMPER assemblies that are in compliance with Rule <R08>,
• The TRAILER,
The Trailer Hitch (as defined in Rule <R18>),
• The OPERATOR CONSOLE
I would not permanently attach the trailer hitch and be prepared to take it off for an inspection. It is possible that the inspectors will know how much a properly constructed trailer hitch weighs and that they might subtract it from your total weight, but I doubt it.
Unread 09-01-2009, 19:53
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
This is a point I'm torn on.
I'd rather the hitch not be ripped off the back of the robot. We're actually going to reinforce the hitch point somewhat just because we believe the trailer will be the biggest weakness for a pin...
So what are the ideas floating around there to have a strong, rigid, but removable hitch mount (other than several bolts that will probably be included in the weight of the bot...)?
GitHub
Unread 10-01-2009, 00:50
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Use whatever size hardware uses the same wrench size as the inside width of the steel tube spacer included in the kit. Mount the hitch so that the nuts are inside the spacer and you simply thread the bolts in from the inside of the frame. It's easy, quick, and you can move on to more important problems.
Unread 10-01-2009, 00:56
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
That's a big nut!
There must be a better way.
Trailer Hitch ewyllie59 Technical Discussion 8 24-01-2009 15:00
Trailer Hitch Question hawk_11 Rules/Strategy 4 06-01-2009 20:21
Trailer Hitch Location geekofband007 Rules/Strategy 6 06-01-2009 19:46
Trailer Hitch ewyllie59 General Forum 7 06-01-2009 08:33
