Go to Post I guess it's true, 'There is no replacement for displacement'. - Andy A. [more]
Unread 10-01-2009, 01:03
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: Wireless Connection Problem
Originally Posted by Mike Wittman View Post
The simple answer is after you set up your network ip addresses power cycle everything in order. I don't know why but sometimes the IP address doesn't take until you power cycle the router and bridge.
This is the power cycle order
1 Router
2 Driver station (wait until it boots up) then go to step 3
3 cRIO
4 power up the wireless bridge
Our team has similar issues with the driver station getting stuck in No-Comm mode. We have the router and the driver station on the same power strip.
So we do a similar power cycle if stuck in the No-Comm loop.
1 Router/DS (power strip)
2 cRIO / wireless bridge (main battery switch)
Most of the time the communication works slowly but surely. The No-comm failures are small but it could be annoying if teams have to wait a minute for the system to startup and then possibly have to power cycle.
We are using Update 2.0 default code with 802.11b/g (because we don't have N laptops )
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Wireless problem - losing communication jalburty FRC Control System 9 09-01-2009 07:35
Wireless Programming FRC4ME Programming 14 14-04-2008 00:22
problem with connection seanl Programming 1 29-01-2007 10:41
USB DAQ Wireless connection? StevenB National Instruments LabVIEW and Data Acquisition 1 01-01-2006 03:49
Wireless Connection on Pocket PC - AEGIS and Odyssey sanddrag IT / Communications 2 07-01-2005 15:51
