Go to Post They have obviously figuered out something special. I want to learn from them. - dlavery [more]
Unread 01-10-2009, 09:47 AM
JDM JDM is offline
programming lead; team executive;..
FRC #2199 (Robo-Lions)
JDM is on a distinguished road
Re: Programming the joystick trigger...
There's a function of the Joystick class called "GetTrigger".
So, the code that you would want to use would be something like the following, where m_Stick is the name of the Joystick object that you want to check.
if (m_Stick->GetTrigger()) {
I hope this helps.
Unread 01-10-2009, 10:25 AM
pudgeball pudgeball is offline
AKA: Nick McGuire
FRC #2386 (BCHS Trojan Robotics)
pudgeball is an unknown quantity at this point
I hope this helps.
The one thing I find when we try to use '->' is that I get an error; "error: base operand of `->' has non-pointer type `Joystick'". So my around that error was/is;
if (m_Stick.GetTrigger()) {
I finally did get the code to work. With that fix mentioned above. But thank you for your help.
Joystick Programming greatman05 Programming 11 01-30-2008 08:40 PM
Single Click On/Off Using the Trigger in EasyC IraJason Programming 15 06-01-2007 11:37 AM
Joystick Programming LieAfterLie Programming 7 02-15-2007 09:30 AM
Programming a Joystick sbf2009 Programming 3 02-10-2007 03:59 PM
Programming the second joystick in PBASIC archiver 2001 2 06-24-2002 12:25 AM
