Go to Post Remember this: A true leader needs no title to make a difference. - Molten [more]
Unread 10-01-2009, 11:10
Marlfox's Avatar
Marlfox Marlfox is offline
FRC #1566 (Ammoknights)
Team Role: Electrical
Marlfox is an unknown quantity at this point
Re: cRIO Problem
How do you configure the router?
You're about to be struck by a vehicle!
Unread 10-01-2009, 11:39
Pneumaticsman's Avatar
Pneumaticsman Pneumaticsman is offline
AKA: Mitch guzman
Pneumaticsman will become famous soon enoughPneumaticsman will become famous soon enough
Send a message via MSN to Pneumaticsman
Re: cRIO Problem
nevermind we got it working
be prepared for the unexpected
Unread 10-01-2009, 11:59
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: cRIO Problem
For all of your getting started configuration needs, please consult the following documents at USFIRST.ORG. The first is the official launchpad with "every" link. You'll definitely need to go through the first 5 chapters in sequence (painful but critical). The other two links are for LabVIEW training (and were obtained from the launchpad site).
http://www.usfirst.org/community/frc....aspx?id=10934
http://decibel.ni.com/content/docs/DOC-2631
http://decibel.ni.com/content/docs/DOC-2663
Russ
CRIO Error 60 seanl FRC Control System 14 18-01-2009 16:29
cRIO fuse??? 20 or 30? mynameisbob Electrical 12 09-01-2009 11:33
cRIO feedback Maxpower57 C/C++ 2 08-01-2009 19:06
cRIO plugin problem gabrielse National Instruments LabVIEW and Data Acquisition 3 18-12-2008 11:30
cRIO test drive *OFB* problem.... NetSkay FRC Control System 5 10-12-2008 18:32
