Re: CRIO Error 60
Yeah probably a bad assumption. Okay, thanks for your help!!!
Re: CRIO Error 60
My team still cannot get the cRIO to update. Still getting error message: "The specified IP address is unreachable. Ensure that the IP address is on the correct subnet." We do not know what the problem is and we will try to get IT help today. We have been using a computer running vista basic 32 bit(dont know if that matters). I have Norton Antivirus so I have been shutting off the firewall and intrusion prevention. On the internet settings in TCP/IPv4 I have set the IP address to 10.23.45.6 and the subnet mask to 255.0.0.0. After trying the imaging we still always come up with the 'error' as seen above.
Any help would be much appreciated -A pleading cry from all of us here at 2345. |
Re: CRIO Error 60
If that still does not work call NI and they will help you. That is what I did and I found out that it was a manufacture problem. The number is 1-866-511-6285 1-7pm Central and just tell them your team number! |
Re: CRIO Error 60
Re: CRIO Error 60
Hey thanks we have got the problem solved. We think it was the computer..
| LebView Error -- Error 1055 occured at Property Node in FRC Create Project.vi->FRC Wi | RMS11 | Programming | 8 | 08-12-2008 18:20 |
| Error in code light on, trouble finding error | Bryan Herbst | Programming | 16 | 12-10-2007 21:59 |
| 180:Error: syntax error help! | seanl | Programming | 8 | 04-02-2007 11:31 |
| stupid Array error: Error [1300] stack frame too l | Validius | Programming | 7 | 27-01-2006 10:53 |
