Go to Post You know FIRST is on the level of sports when you can give predictions like sports casters do. :) - RoboMaster [more]
Unread 10-01-2009, 12:58
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Finding green/pink flags
Originally Posted by DaveD View Post
There are bugs in the current versions of FindColor, GetLargestParticle and InArea. These have been fixed at the beta level and should be published shortly along with the pink-green demo that Brad mentioned above.
Dave D
(not directly to dave D)
If you're a team that simply can't wait, you can look at GetLargestParticle and FindColor in TrackApi.cpp. Notice that GetLargestParticle never actually returns the largest particle index to the 2nd parameter. The code to return isn't there, and in the 2nd line of the function it actually blows away the pointer value so it becomes impossible to return the largest particle index. Since it's probably not a good idea to go fiddling with the supplied code unless you know what you're doing, I'll leave it as an exercise to the reader to figure out what to do.
Further, in the full-size version of FindColor, its check for success is incorrect. Rather than "if(largestParticleIndex == 0), it seems that it should be if(largestParticleIndex >= 0) in case the largest particle is not the first one.
Flags???? cprogrammer Programming 4 25-07-2005 20:21
Flags trdragons204 General Forum 2 23-03-2005 10:29
Concerns regarding the green paneling/green shirts Petey General Forum 127 15-01-2005 10:35
6 Flags Raven_Writer Chit-Chat 12 30-07-2004 23:01
Six Flags? Hermione692 Championship Event 29 29-04-2003 21:12
