Go to Post However, mentoring isn't for you. It's for the others. - Alan Anderson [more]
Unread 05-01-2009, 19:57
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
This year's Fisher Price motors
I know I'm going to get yelled at, but here goes. YES, I "searched" but did not find the answer. Are there any new specs for the Fisher Price gearboxes and motors? I know that they change each year and I cannot afford to be off by much this year.
Unread 05-01-2009, 23:57
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: This year's Fisher Price motors
They're the 00968-9015 motors, manufactured by Johnson for Fisher-Price. This year, they've got the 16-tooth gears. Last year, the same motors were provided (with 19 teeth on the pinion), and FIRST posted the specification sheet here. (See other 2008 specifications here.)
The motor pinions are 0.8 module (or possibly 32 pitch—these are virtually indistinguishable) and 20° pressure angle.
Since the F-P gearboxes fit 16-tooth motors this year, they're of a different design than the 19-tooth ones provided last year. Be careful with the COTS rules on those 19-tooth gearboxes, from 2008 and otherwise: F-P service centres stock the motors and the gearboxes together as an assembly, and won't sell them directly to FIRST teams under most circumstances. If you plan to use them, make sure that there is a vendor (in the FIRST sense of the word) for the parts.
Last edited by Tristan Lall : 06-01-2009 at 00:14. Reason: More discussion of gearboxes.
Unread 10-01-2009, 13:37
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
Are there any specs on this year's gearbox?
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 10-01-2009, 13:48
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
will the motors fit on the AM planetary gearbox?
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 10-01-2009, 14:22
It's the 16-tooth version, but I'm not entirely sure if it's the same 16-tooth one that was provided in the past.
They will, but you're going to have to remove and replace the pinion. I think that AndyMark's instructions describe the procedure.
Unread 20-01-2009, 20:41
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Has anyone tested the validity of this data? Our tests today showed a no-load speed of 19000 RPM, whereas FIRST's document states something close to 15800 RPM - we do have the 16 tooth, 9015 motors, that's for sure. We also tested with a 4.9375:1 gear reduction to make sure the extremely high speed wasn't driving the encoders crazy, and we did get the expected speed reduction (~3800 RPM).
As for the pinions, they are indeed metric: 0.8 module with a 20 degree pressure angle (while the small pinion is virtually indistinguishable from metric to Imperial, the 79-tooth mating gear is not - there's quite a bit of a difference between a 0.8 module and a 32 DP gear this size, and that's how we found out, although rather crudely ).
Manoel Flores da Cunha
Brazilian Machine
Team # 383
are this year's fisher price motors as good as the old ones with the black case? waialua359 Motors 2 11-01-2007 22:51
Fisher Price Motors MechaJagEric Electrical 3 13-02-2003 08:45
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
fisher price motors archiver 2000 4 23-06-2002 22:36
