Go to Post [I]'Twas the night before ship day, And all through the shop, Not a creature was stirring, Not even[/I] -- Naah, they'll never believe that. - GaryVoshol [more]
Unread 10-01-2009, 01:44
DSST\neal.ian DSST\neal.ian is offline
AAHHH!! WHERE'D ALL THE TIME GO?!?!
AKA: Ian Neal
FRC #2240 (Brute Force)
DSST\neal.ian has a spectacular aura aboutDSST\neal.ian has a spectacular aura aboutDSST\neal.ian has a spectacular aura about
Send a message via AIM to DSST\neal.ian Send a message via MSN to DSST\neal.ian Send a message via Yahoo to DSST\neal.ian
Exclamation Connecting to cRio, getting the jaguars to go solid yellow.... then nothing.
The title says it all. What we are doing is a tank drive system; we have it all programmed and we have triple checked theprogram in LabView for any errors, updated everything....... Triple checked the wiring inside the robot...... And the motors do not respond to the joystick commands. We even checked with one of the old motor controllers; still nothing. This has been a problem we have been poring over for almost 6 hours now. HELP!!!!!!!!!!!!! Please?
-2010 Finalists! CO Regional 2010
2240 BRUTE FORCE!!!!!!!
Our site: http://robotics.scienceandtech.org
Unread 10-01-2009, 01:48
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Connecting to cRio, getting the jaguars to go solid yellow.... then nothing.
Did you check the pwm, did you plug it in wrong. We did and the jaguar would keep blinking.
R.C.
MadTown Robotics Team 1323
Unread 10-01-2009, 03:18
AKA: Ian Neal
Checked, double checked, and triple checked. I think.
Unread 10-01-2009, 03:22
Is this even while tethered?
Unread 10-01-2009, 04:56
viperred396's Avatar
viperred396 viperred396 is offline
people have lives during January?!?
AKA: Bryan
viperred396 has a spectacular aura aboutviperred396 has a spectacular aura aboutviperred396 has a spectacular aura about
Yes we connected the computer to the modem and the modem to the robot via eathernet cable. So the wireless is not a problem.
Sorry my spelling sucks and i am to tired to think as it is 3 in the morning
Unread 10-01-2009, 06:09
AKA: Ian Neal
Viper's on my team. Yes, we are tethered, and obviously connecting, as we can make the Jaguar go from blinking to solid.... yellow. It MIGHT be a problem with how I'm connecting though, as I am only running the Tele-Op VI, not the whole robot code; I don't know if that would change anything.
Unread 10-01-2009, 13:41
fritzdejongh fritzdejongh is offline
Coach
FRC #2704
fritzdejongh has a spectacular aura aboutfritzdejongh has a spectacular aura aboutfritzdejongh has a spectacular aura about
Have you checked your battery charge?
We've seen that the control system works fine as the battery voltage drops, but the motors stop responding when the voltage gets below about 11.5V. So, everything looks like a go, you've got solid yellow lights, but nothing moves. You might see blinking red or green lights.
Unread 10-01-2009, 13:50
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
Are you feeding the system and user watchdogs? What is the Watchdog status LED on the digital sidecar doing? Is is blinking or is it solid?
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 10-01-2009, 13:57
AKA: Ian Neal
I spent more than 6 hours last night trying to make it work. I finally got it. I just needed to put in a "DS: start comm". And now it works. we drove it around, and now we have either a slipping chain or some slipping gears. Good thing this is the test bot for the programmers, and not the bot we're using at the competition. Thanks all, though!
In other words, it WAS a problem that I wasn't using the whole robot code. I have that fixed ATM though.
Unread 10-01-2009, 16:46
...and now we have either a slipping chain or some slipping gears...
If you're using toughboxes, check your keys. They fall out all the time. Easy repair and to prevent it from happening is to use a washer in there. But yea, check ur key.
Unread 25-01-2009, 17:03
AKA: Ian Neal
We got that too, and now we just have a crazy SOUNDING toughbox, though that was just in comparison to the newly rebuilt one...... I think we are going to tear it apart and check for that too. Thanks.
Unread 30-01-2009, 18:15
Tack610's Avatar
Tack610 Tack610 is offline
FRC #2413
Tack610 is an unknown quantity at this point
We have this same problem with our bot but we havent touched the programing at all. While someone was driving it, someone else hit theAutonomous switch and the joysticks stoped working. But we have tested them on a computer and they work fine.oh yeahh and we have flasing orange/yellow lights on the jaugar
Joe
Connecting Axis camera to cRIO laultima FRC Control System 20 21-01-2009 16:56
Getting Packets from the cRio rfrank Programming 2 17-01-2009 22:35
Help! Connecting CRIO to the Power Block RyanJK Electrical 3 07-01-2009 17:28
Tricks getting the CRIO to talk to laptop mac7attack FRC Control System 10 08-12-2008 09:20
CMUcam green, no red LED, then nothing rsorrells Programming 2 15-01-2006 22:34
