Go to Post [You know you've overdoes on FIRST when...] You're willing to take an 8 AM for the team. - ttldomination [more]
Unread 10-01-2009, 13:58
Carmelulu` Carmelulu` is offline
FRC #1943
Carmelulu` is an unknown quantity at this point
Assistance in Vision Assistant
Hey, we are from Team #1943.
Our programming crew was unable to fully operate Vision Assistant: we tested it only in its Evaluation version, in which we were unable to form a VI from a Script.
We seem to lack the activation code to run Vision Assistant in its complete, Activated version (we already tried both codes written on the disk we received in the KOP).
If any of you guys knows what the problem is, we would appreciate it.
Thanks in advanced.
Unread 10-01-2009, 15:36
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Re: Assistance in Vision Assistant
Go to the NI License Manager, go down to Vision 8.6, right click on NI Vision Assistant FRC, hit activate, try the code you have.
I'm going to guess that you are trying to you are trying to activate the non FRC version, which won't work.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Axis Camera responding in the Vision Assistant but not in WindRiver DanDon C/C++ 3 11-01-2009 12:50
pic: Assistant Coach & Team Member working together :) amityschool Extra Discussion 7 06-02-2008 22:28
"Transmission Design Assistant" Greg Perkins General Forum 15 18-09-2005 23:52
pic: Big Mike the Sign Guy & Assistant Chell CD47-Bot Extra Discussion 10 22-07-2003 16:52
BuzzWriter - PBasic Assistant archiver 2000 0 23-06-2002 22:58
