Go to Post Is FIRST making it too easy?... yes they are making it easier than years past. But I would also say that does that matter? If students are still inspired to pursue more advanced designs and eventually a career in the technology sector we still have met our ultimate goal. - MikeDubreuil [more]
Unread 10-01-2009, 15:17
jescholler jescholler is offline
FRC #0093
jescholler is an unknown quantity at this point
MaxBotix LV-MaxSonar-EZ4
I tried testing the MaxBotix LV-MaxSonar-EZ4 sensor from SparkFun. I was using the analog output and the waveform varied from near 0V to approximately 1V like a square wave. The pulse width was not constant. I'm not concerned with what the voltage level was on the high side, but as far as I understand, the analog voltage should be fairly constant.
I tried implementing the filter (100k resistor and 0.1uF capacitor) that MaxBotix recommends on their FAQ, but that only rounded the edges of the squar wave.
In case you were wondering, I am positive that I'm connected to the analog output and not the PW output.
Has anyone had this problem with this series of sensors, and if so, what did you do to fix it?
Mounting Maxbotix rangefinders pogenwurst Sensors 7 06-07-2008 22:09
Maxbotix Ultrasonic Sensor Help... manderson5192 Programming 9 22-02-2008 14:25
Parallax and Maxbotix ultrasonic sensors Lucretius Programming 5 20-02-2008 14:34
LV-MaxSonar-EZ1 marccenter Programming 2 06-02-2007 19:25
Maxbotix Sonar Sensor DonRotolo Electrical 17 04-02-2007 12:27
