Go to Post Dangit Jim, we are engineers not politicians. - Andrew Schreiber [more]
Unread 10-01-2009, 17:17
program1's Avatar
program1 program1 is offline
AKA: RJ
FRC #2441
program1 will become famous soon enough
Downloaded program, but no response
we assembled electrical components and control system, then pushing our joystick forward makes our motor spin...so i guess we did the benchtest?..
then, i updated the cRio firmware and driver station firmware and also changed all ip adresses.
we downloaded the basic code from the dvd and then updated it, then deployed it to the cRio.
we still have our jaguar pwn connected the first slot. we powered everything on, yet all we get now is flashing yellow lights.
does anyone know if we missed a step here?
thanks.
ok, who ate my hot pocket?
Unread 10-01-2009, 17:19
computerboi1503 computerboi1503 is offline
Programmer/Driver/Spokesperson
AKA: A former me.
FRC #1503 (Spartonics)
computerboi1503 will become famous soon enoughcomputerboi1503 will become famous soon enough
Re: Downloaded program, but no response
Did you reset the robot after downloading code?
Unread 10-01-2009, 17:29
program1's Avatar
AKA: RJ
FRC #2441
Thank you for your quick response. We did not know that.
BUT...
We redownloaded the program, then press reset, then the yellow status light on the cRio went on and then off
and then we turned the power off, plugged in the wireless bridge.
Then, we turned everything on, waited, and it is still flashing....
Unread 10-01-2009, 18:35
Stimpy1901 Stimpy1901 is offline
AKA: Bobby
FRC #2348 (Cool Geeks)
Stimpy1901 will become famous soon enough
thanks.
Did you use update version 7 in the imaging tool?
I assume you mean the jaguar lights are flashing. From my experience, there are two reasons for this light to flash: (1) not connected to a motor and (2) not receiving signal from pwm (a programming or connection issue).
Do you get a battery voltage display on the DS or some other message?
Unread 10-01-2009, 18:42
brianc217's Avatar
brianc217 brianc217 is offline
None #1153
brianc217 is an unknown quantity at this point
i believe flashing yellow lights are normal
to download programs to the robot you turn everything on and deploy the code to the crio using the white arrow in labview, make sure the robot is set to disabled on the driver station. then you can simply enable the switch on the driver station. if you turn the robot off after you download the code, then the code will be deleted because its only in temporary memory. to make it permanent in labview you right click dependencies and click build. then you right click dependencies and click run at startup.
i downloaded the source code, now what do i do? programmr Programming 2 12-12-2008 14:39
Autodesk's response Koko Ed 3D Animation and Competition 7 20-01-2007 16:52
Problem with the program downloaded to the controller itsme Programming 9 14-01-2007 12:12
Downloaded models Josh Siegel 3D Animation and Competition 10 06-02-2004 21:42
Sensor response time... randomperson Electrical 4 21-01-2003 10:41
