Go to Post "Mentors Only Work When Being Calibrated". - Calvin Hartley [more]
Unread 07-01-2009, 23:58
JamesByrne's Avatar
JamesByrne JamesByrne is offline
FRC #0360 (The revelution)
JamesByrne is on a distinguished road
How To Wire The Encoder
We have some Andy mark encoders and we have used them on the 2008 control system and systems in the past. Can anyone tell me how to plug them into the 2009 control system.
Unread 08-01-2009, 00:01
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: How To Wire The Encoder
Essentially, you have the A-channel, B-channel, ground, and power terminals. So...supply the power and ground appropriately.
Unlike previous years, where interrupts were only available on certain pins the the PIC18, this year you get to pick the ports for each channel. Use the signal line and ground line of two 3-pin cables to attach the A-channel and B-channel to two GPIO connections on the digital side cars, select the appropriate pins when you program, verify operation...and you're all set.
Unread 09-01-2009, 14:29
eitang eitang is offline
Hamosad 1657
AKA: Eitan Galon
FRC #1657 (Hamosad)
eitang has a spectacular aura abouteitang has a spectacular aura about
if i connect the encoder using all 3 connections (a channel,+,-) on one pwm cable and another cable just the b channel with out the + and - will it work?
Unread 10-01-2009, 17:11
morganh2550's Avatar
morganh2550 morganh2550 is offline
Actuationator
FRC #2087 (BFG)
Team Role: Electrical
morganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nice
Lightbulb Re: How To Wire The Encoder
I don't think that will work.
Unread 10-01-2009, 17:41
FRC #6357
Yes, you can use the red wire in the PWM cable to supply voltage.
You certainly need at least the ground and signal wires on both channels. This allows you to tie the grounds for each wire together at the encoder. The voltage supply should come from one of the two wires.
What you suggest will work, with one modification. Making the A channel PWM cable "fully wired" (i.e. +5, GND, and SIG all wired) works de facto. The B channel PWM cable should have the ground wire connected to the encoder ground, the signal wire connected to the B channel encoder wire, and the +5V wire terminated and insulated.
-Jeff
Unread 19-01-2009, 12:56
comwiz7's Avatar
comwiz7 comwiz7 is offline
AKA: Joey
FRC #1323 (Madtown Robotics 1323)
comwiz7 will become famous soon enoughcomwiz7 will become famous soon enough
Send a message via MSN to comwiz7
Could someone make a simple diagram for wiring the encoder? I haven't been able to figure it out from this post and I can't find any documentation.
Unread 19-01-2009, 13:15
This thread has confused me a bit...
On the digital side car's digital input/output header, the ground pins are all tied together and the power pins are all tied together. There is nothing to force you to use the power or ground pin that correspond to a given I/O pin.
You need to pull (at least) one power line, (at least) one ground line and the two signal lines over to the encoder. If you want to pull plural power or ground, you may do so.
I think the easiest method might be to use a 1x4 cable and using the extra two power and ground pins that are in line with the signal pins.
How do you wire up the Operator Interface? iPilipino Electrical 6 22-01-2008 00:22
How do you wire the wheel encoders? Demothesis Electrical 2 17-07-2007 16:59
how do you wire the team light coolguybigt Robot Showcase 2 21-02-2007 22:18
how to wire the pneumatic diagram yara92 Pneumatics 0 17-02-2007 16:28
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
