Programming a relay in C++
How do you do it? this is probably too general a question, but we just started using C++ for this build season, and we're pretty inexperienced. So we need to know how to properly initialize it, and just basically how to do it. sorry if that's not a good explanation, or if the subject is too broad.
Re: Programming a relay in C++
In this season's code, you would do the following:
Relay myRelay([slot],[chanel],kBothDirections); //initialize the relay in slot [slot], channel [channel], and allow it to move both directions myRelay.Set(kForward); //turn the relay on in the forward direction myRelay.Set(kOff); //turn the relay off If this isn't enough detail, just say so. |
Since the enumerated members are in the Relay class, you need
myRelay.Set(Relay::kForward) Also, since the constuctor defaults to kBothDirections, you don't need to include that parameter. So, to initialize a relay object called "r41" on DSC 4 relay channel 1 using the default mode (kBothDirections) and set it forward you'd use: Code:
Relay r41(4,1); r41.Set(Relay::kForward); |
| Programming a single relay to two buttons in easyC Pro? | Gizmo2417 | Programming | 1 | 17-02-2008 17:10 |
| Easy C Relay Programming | Team_486 | Programming | 1 | 26-03-2007 15:01 |
| Pneumatics (Spike Relay, Solenoid etc.) Programming | oceansidehs | Programming | 8 | 10-02-2007 13:58 |
| Relay Programming Questions... | comwiz7 | Programming | 11 | 21-02-2006 13:04 |
| Relay Assignments | MulletFish | Programming | 9 | 27-01-2005 14:15 |
