Go to Post PS. Never write to a forum when your cat is trying to lie on the keyboard while you type. It made my bad spelling worse. - Seth Mallory [more]
Unread 10-01-2009, 18:01
computerboi1503 computerboi1503 is offline
Programmer/Driver/Spokesperson
AKA: A former me.
FRC #1503 (Spartonics)
computerboi1503 will become famous soon enoughcomputerboi1503 will become famous soon enough
cRIO Problems
Hi,
Since updating WR and reimaging the cRIO, we have had a few problems.
Problem #1:
Downloading code takes nearly ten minutes
Problem #2:
When code is downloaded, and after cRIO+ DS is restarted, the DS displays "No Code"
Suggestions?
Unread 10-01-2009, 18:48
brianc217's Avatar
brianc217 brianc217 is offline
None #1153
brianc217 is an unknown quantity at this point
Re: cRIO Problems
can you run the code that you download?
Unread 10-01-2009, 18:51
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: cRIO Problems
Have you also patched WindRiver, LabView, and the Driver's Station to the newest versions as well?
Unread 10-01-2009, 22:59
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Re: cRIO Problems
1) Are you fully updated?
2) By downloading do you mean deploying? Or does it take 10 minutes when you hit the white run arrow. You shouldn't be deploying too often.. running it from the laptop is much faster. Deploy when you're done.
3) Is the "No App" switch on the cRIO switched to Off like it should be?
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 10-01-2009, 23:01
1951-44U's Avatar
1951-44U 1951-44U is offline
ROAR.
AKA: Phil Chang
FRC #0025 (Raider Robotix)
1951-44U has a spectacular aura about1951-44U has a spectacular aura about1951-44U has a spectacular aura about
Re: cRIO Problems
Did you configure the right .out file?
Windows >> Preferences >> FIRST Downloader Preferences
If you get the wrong one, it won't work. It should be the same name as the project you are working on.
Unread 10-01-2009, 23:13
Re: cRIO Problems
Whoops, completely missed that you're using WR. Skip my second point!
Unread 10-01-2009, 23:35
CardcaptorRLH85's Avatar
CardcaptorRLH85 CardcaptorRLH85 is offline
The master of the cards ^_^
AKA: Raa'Shaun H.
FRC #0322 (F.I.R.E. "Flint Inspires Real Engineers")
CardcaptorRLH85 is an unknown quantity at this point
Send a message via ICQ to CardcaptorRLH85 Send a message via AIM to CardcaptorRLH85 Send a message via MSN to CardcaptorRLH85 Send a message via Yahoo to CardcaptorRLH85
Re: cRIO Problems
Originally Posted by computerboi1503 View Post
Hi,
Problem #1:
Problem #2:
Suggestions?
Our team has never had that first problem however, we have had the "No Code" error before. Once was when I updated the WPILib to 1.2 but neglected to update the cRIO to v7 >_<
However, even after making sure that everything was updated, I still got the "No Code" error. The problem was that the code I ws trying to load was from a new VxWorks 6.3 Downloadable Kernel Module Project that I created instead of just editing one of the examples. If you've already updated everything and are still having problems, try creating a new copy of one of the examples and loading it. If that works then you may be suffering the same problem as we were.
By the way, this isn't in any of the references or manuals (in fact right now the 'Create An Application' page is blank >_<) but, how exactly what settings would have to be set to make a project from scratch. I'm only somewhat familiar with eclipse and my knowledge is from eclipse 3.4x not the 3.3x that WindRiver is based on so any information will be of great help ^_^
Unread 11-01-2009, 09:35
AKA: Brad
#0190 ( Gompei and the Herd)
Re: cRIO Problems
Look at the Users Guide in c:\windriver\docs\extentions\FRC. It has examples of how to create a project from scratch. The way to do it is to take one of the sample programs and edit it into your robot program. The examples are very short and easy to understand. In particular, you might try "SimpleTemplate" and fill in your Autonomous and OperatorControl methods. There's some stuff in the Users Guide that walks you through it.
Brad Miller
Robotics Resource Center
Problems reimaging cRIO ravena Technical Discussion 13 17-02-2009 20:19
cRIO Problem Pneumaticsman NI LabVIEW 8 10-01-2009 11:59
Problems undeploying a program from the cRIO ellisk Programming 2 29-12-2008 16:21
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
