Go to Post I will test first 'cause you cannot learn unless you break something first! - Andy Brockway [more]
Unread 10-01-2009, 14:28
ttldomination's Avatar
Sunny
[FTC]: Lego Motor Extension Cord?
Hello,
We have a LEGO motor sitting at a considerable distance from the NXT and we need a longer cord than provided in the kit, does anyone have a way to create a long distance connection?
Thank You
1648: 2013-2014
5283: 2015
Unread 10-01-2009, 18:56
gdo's Avatar
gdo gdo is offline
Never too much duct-tape ;)
AKA: Patrick
FTC #0001 (Team Unlimited)
gdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to behold
Send a message via AIM to gdo Send a message via MSN to gdo
Re: [FTC]: Lego Motor Extension Cord?
One thing that we did was use some of the interface cables from the NXT to RCX cable. You can take two of these cables and combine them at the RCX connection and make a very long cable. If the cable is longer than that that you need, you might want to move the NXT closer to the motor in question.
You can get the cables here
Also, HiTechnic sells "Extra long cables", You can find the at the bottom of this page
I hope this helps out.
Regards,
~FTC #1, Team Unlimited
FTC #1: http://unlimited.syraweb.org
Got any question for me; AIM, MSN or PM me
Unread 11-01-2009, 11:52
Sunny
WOW THANKX!!!!. I'm not sure if we can use the extended set, but i'll ask on Q and A forum, and the RCX trick is greatly appreciated.
1648: 2013-2014
5283: 2015
[FTC]: Random Error with FTC motor control Xaphiinia FIRST Tech Challenge 2 01-12-2008 15:39
[FTC]: Conveyor Belt Lego Parts Shimoniskey FIRST Tech Challenge 7 18-11-2008 19:58
[FTC]: Lego Axle Question ttldomination FIRST Tech Challenge 3 05-11-2008 09:29
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
[FTC]: [FTC] Motor Controller problems michael714 FIRST Tech Challenge 4 14-10-2008 00:33
