Go to Post FIRST is kind of like charity work... you are, even if only in some small way, helping our future just a little bit, and you get a great feeling from it. Even if you are just ringing a bell (or clapping MOE sticks together), you're helping. - Amanda Morrison [more]
Unread 10-01-2009, 19:25
king vash king vash is offline
FRC #2635 (Hazmat)
king vash is an unknown quantity at this point
C++ code terminates instantly
In windriver in debug mode it either gives memory access error or terminates. We have completed the benchtop test, and believe cRIO and driver station are updated.
Any ideas?
Driver station reads DS : 2008-10-29a (even though update was labeled nov 1st)
Unread 10-01-2009, 20:11
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
Re: C++ code terminates instantly
It might be one of these:
1) did you "undeploy" the running program before downloading?
2) did you set it to "Automatically attach spawned kernel tests"?
(that's in the debug options in the menu when you right-click
the project in the project explorer window)
Either of these may cause that problem
Also, the update was labeled nov. 1st, but that is the correct info in the display - ours also read that and is updated/operational
CRUD Name: Windows
Alumni to Team: 350
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
how to convert Easy C code into real code? TheHolyLancer Programming 1 29-01-2006 09:09
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Chat Instantly - Florida <=> South CA <=> Boston NOW! soap108 General Forum 26 03-06-2003 11:43
