Go to Post It keeps your minibot from being destroyed by Dean's chainsaw, which is a big competitive advantage in future matches. - Joe Ross [more]
Unread 10-01-2009, 15:57
Lord Byron's Avatar
Lord Byron Lord Byron is offline
AKA: Tim Sebek
FRC #0538 (Dragon Slayers)
Lord Byron is an unknown quantity at this point
Cannot change ds team number
We are have trouble changing our team number on the driver station.
We have the firmware updated. When we hold the down button nothing happens. What do we do?
We have tried with enabled/disabled, tele/auto, everything disconnected, everything connected, and with the laptop connected, but we still cannot get it to work. Is there some sort of combination we could be missing?
You have a ramen doctor in your secret ramen base!?!
Unread 10-01-2009, 19:49
Lord Byron's Avatar
AKA: Tim Sebek
Re: Cannot change ds team number
Update, our driver station suddenly worked (we did nothing to it) and allowed us to change the the number on the 40th something try
Unread 12-01-2009, 23:55
Honis's Avatar
Honis Honis is offline
AKA: Nate
FRC #2478
Honis is an unknown quantity at this point
Any hints as to how you had it setup would be appreciated. I'm having this exact same problem with my DS.
[edit] After reading this helpful thread http://forums.usfirst.org/showthread.php?t=10825 I did what I should have done.
Unread 15-01-2009, 17:54
Lord Byron's Avatar
AKA: Tim Sebek
We had done that. Ours just wouldn't work until the 40th-something try. (We had given up on new ideas by that point)
Now it works fine. Great device right?
Unread 16-01-2009, 01:12
Honis's Avatar
AKA: Nate
FRC #2478
Once we had a firmware without the *OTB* on the screen everything worked first time.
Sounds like a same symptoms different cause thing.
Driver Station not allowing team number change Bryan Herbst FRC Control System 2 04-01-2009 12:26
Cannot force 2004 RC into automode with team number 0 bear24rw Programming 0 07-10-2007 20:42
team number change savage General Forum 5 03-10-2006 23:26
Change Team Number on 2004 RC bob2004 Programming 4 18-02-2004 22:08
bug: Can't change team number to Team 0 Joe Ross CD Forum Support 1 18-12-2003 09:52
