Go to Post Building things from scratch builds character. - davidthefat [more]
Unread 10-01-2009, 20:04
morganh2550's Avatar
morganh2550 morganh2550 is offline
Actuationator
FRC #2087 (BFG)
Team Role: Electrical
morganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nice
Exclamation pneumatics bumper
how does one go about hooking up a solenoid to the pneumatics bumper???
Unread 10-01-2009, 20:39
Re: pneumatics bumper
You use a 2-pin connector. Several of these came in the Kit with 2-pin connectors at both ends. You can cut one of those in half to get two connectors.
Then connect that cable to the two wires of the solenoid and plug in into the pneumatics bumper.
Unread 10-01-2009, 21:08
Actuationator
FRC #2087 (BFG)
Talking Re: pneumatics bumper
will this work 4 the festo valves and so there is no need 4 a spike?
Unread 10-01-2009, 22:07
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
As long as the valves run on 12V and less than 3/4A of current, they'll operate just fine with the Solenoid Breakout.
The only tricky thing - the Spikes are full H-bridges and teams have often exploited that to drive a pair of anti-parallel valves. With the Solenoid Breakout, you'll have to implement that "this-one-or-that-one-or-neither" logic in software.
Russ
Unread 10-01-2009, 22:16
The Festo valves can be run directly from the Pneumatic Bumper without a Spike.
Bumper Qs Woody1458 General Forum 13 29-01-2009 16:41
Bumper Mounts Sam N. Technical Discussion 18 17-02-2008 20:19
bumper coolguybigt Technical Discussion 4 27-02-2007 16:40
bumper weight chippermonky Technical Discussion 10 09-02-2007 14:42
Bumper or No? WebWader125 Technical Discussion 19 11-01-2006 01:28
