Go to Post I wonder if Dave thinks the Chief Delphi kids are pimp... - Mike Ciance [more]
Unread 10-01-2009, 20:46
rjohnson rjohnson is offline
FRC #2172 (Street LEagle)
rjohnson has a spectacular aura aboutrjohnson has a spectacular aura about
Just two wheels and a trailer
Arguably, discussion on wheels has been the most common topic this year. After reading many posts on this topic, I have not seen anyone talk about what I am about to propose.
I am thinking that you could use just two wheels on the robot with an axis parallel to the axis of the trailer and somewhat centered front to back. From what I understand the tongue is pretty rigid and would allow to trailer to act as the other balancing wheels. This configuration would allow for greater turning capabilities and virtually all the weight of the robot would be over the wheels (assuming if was placed close to the center of gravity of the robot) for maximum traction. The official drawings say that the tongue itself is aluminum and the tongue accessories are made of steel. I don't think this would put too much stress on the tongue as most of the weight would be centered on the robot wheels.
Please anyone share their thoughts concerning the viability of the design or other advantages/disadvantages that I have not considered.
Unread 10-01-2009, 20:51
m^3's Avatar
m^3 m^3 is offline
AKA: M. M. M.
FRC #2040 (DERT)
m^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant future
Re: Just two wheels and a trailer
You might want free spinning wheels on the front that would support the robot when no trailer is present, but rise a few mm off the ground with a trailer. Otherwise, I don't see a problem with it. If you do try it, could you post a vid?
Unread 10-01-2009, 20:53
Hanna2325's Avatar
Hanna2325 Hanna2325 is offline
Programmer/Driver
AKA: Hannah
FRC #2177 (Robettes)
Team Role: Driver
Hanna2325 will become famous soon enoughHanna2325 will become famous soon enough
Send a message via AIM to Hanna2325
its interesting, especially if you do it in a way that gives you a lot of control. Ya, and a video would be great!
that light is NOT yellow, its orange! Where is the yellow light?
:1..2...3...BEAST!:
Unread 10-01-2009, 21:16
Dick Linn's Avatar
no team (Synergy)
http://www.chiefdelphi.com/forums/sh...t=71238&page=4
See the picture attached to post # 60. I was essentially asking the same thing, but I thought the trailer tongue was more rigidly coupled at the time. So the "sulky" is the trailer. Go for it! Simple is better.
(Yes, you would need a caster or idler wheel of some sort in the back when nothing is hooked up, but that's no biggie...)
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 10-01-2009, 21:20
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
although the tongue is rigid on the trailer, there is a lot of movement between the hitch connector at the trailer hitch and the hitch itself.
try some experiments, but i think the looseness (in the verticle axis) is enough that the trailer tongue and back of the robot would sit on the field surface.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 10-01-2009, 21:44
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
We went down this road for a while but decided the hitch was just too weak.
Ed Sparks
MECH TECH FRC-3959
Unread 10-01-2009, 22:20
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
We did test this method, we built two trailers and found that both allow too much movement, also the rules state that the hitch is to be 2 13/16 inch off the ground and with the robot tipping forward and back that distance change would violate that rule.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Low-Cost trailer drawings? (was: Trailer) DM7000 General Forum 2 07-01-2009 16:54
pic: Mike Wade and his trailer Carol Extra Discussion 19 18-12-2007 21:00
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Putting two and two together... Andy Grady General Forum 13 08-01-2004 18:29
To Maximum Oz and Two Train Joe Matt Thanks and/or Congrats 1 09-03-2003 13:03
