Go to Post Another year, another picture of a Tytus injury. - Andy Baker [more]
Go Back   Chief Delphi > Other > FIRST-related Organizations > The Blue Alliance
Unread 10-01-2009, 21:53
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Post [TBA]: Team info update?
Greetings TBA. I'm with Team 2656, entering our second season of FRC. I was just looking at our page on the TBA website (which is awesome BTW) and a thought occurred to me... We've updated our team name/nick name on TIMS and added URL's there for our website and blog. I'd like to see this information mirrored on TBA, but I wasn't sure how/if I could update that. I assume that you all have something that syncs data with FIRST/TIMS? If so, then I guess we'll be all good after the next update and I won't worry about it any longer. If not, let me know and I'll be happy to submit further information for Team 2656. Thanks. I really like what ya'll and doing at TBA and we've got a link to our page there on the main page of our website. Please, keep up the great work!
Unread 10-01-2009, 22:17
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: [TBA]: Team info update?
I just went to run an update of the team data, and it seems that FIRST is doing something to block scripts from downloading team data. I am not sure what is going on, but (https://my.usfirst.org/myarea/index....=FRC&team=1388) gives me different source code depending on if I open it in Chrome or wget it, and I can't open the URL at all from my PHP scripts that worked last spring.
I will investigate this further, but we will do a complete team data update before ship date.
Thanks!
Unread 10-01-2009, 23:23
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Thanks!
I'm curious if they were having an issue with abuse.
Eric Haskins KC9JVH
Unread 11-01-2009, 22:45
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Sounds like user agent sniffing to me. Could be hacked by setting the user agent (i.e. in PHP as described here) in whatever scripts are used, but it seems to me that a site as prominent in the FIRST community as TBA should be able to work out something a little more "over the table" with FIRST.
--Ryan
FRC 766, 2015-, Mentor
Unread 12-01-2009, 02:29
Matt Keller Matt Keller is offline
FRC #0108 (SigmaC@T))
Matt Keller has a reputation beyond reputeMatt Keller has a reputation beyond reputeMatt Keller has a reputation beyond reputeMatt Keller has a reputation beyond reputeMatt Keller has a reputation beyond reputeMatt Keller has a reputation beyond reputeMatt Keller has a reputation beyond reputeMatt Keller has a reputation beyond reputeMatt Keller has a reputation beyond reputeMatt Keller has a reputation beyond reputeMatt Keller has a reputation beyond repute
The issue is that they switched TIMS data over to a secure site, and PHP lacked any SSL support until 4.3.0, and ever since it has been rather flaky. As an alternative without fooling with any libraries, you may be able to use fsockopen() to create a SSL or TLS socket. More than likely your host has heavy restrictions on socket-related functions, especially if you are on a shared hosting plan.
When they made the switch last season, I immediately updated my scripts to utilize the cURL library, which works beautifully in this situation. Many hosts now support it and I definitely recommend going this route.
Here would be a simple cURL replacement for file_get_contents():
<?php
$ch = curl_init();
$timeout = 5; // set to zero for no timeout
curl_setopt ($ch, CURLOPT_URL, 'http://example.com');
curl_setopt ($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt ($ch, CURLOPT_CONNECTTIMEOUT, $timeout);
$file_contents = curl_exec($ch);
curl_close($ch);
// display file
echo $file_contents;
and a replacement for file():
<?php
$ch = curl_init();
curl_close($ch);
$lines = array();
$lines = explode("\n", $file_contents);
// display file line by line
foreach($lines as $line_num => $line) {
    echo "Line # {$line_num} : ".htmlspecialchars($line)."<br />\n";
If you are unable to use these methods and can not get anything to work, I am more than willing to help out.
Hope this helps!
sigmacats.org @frc108
Unread 12-01-2009, 06:08
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
I think a more likely explanation is they are trying to optimize the page for the user agent it detects. Their site has to handle a large amount of traffic and intentionally blocking screen scraping seems like a wasted effort to me.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 12-01-2009, 09:32
I don't think they do any page optimization based on client. FIRST's TIMS system is pretty old and hasn't seen any substantial updates in the last few years. What would be the best is if they implemented an actual API that provided structured XML so that teams could more easily write applications that utilized FIRST's data.
Ultimately, I feel that FIRST underutilizes their website, and could do a lot to promote and help the community. Potential sponsors and people looking for "official" info need a very different experience than students and mentors currently on teams, and I don't think FIRST does a very good job catering to the latter group right now.
Unread 12-01-2009, 20:31
Boiler Up
AKA: John Downey
If FIRST had an API to retrieve public information from TIMS it would probably make many lives easier. However from my understanding they outsource almost all of that stuff to a company, 4x media or something similar.
John Downey
Unread 12-01-2009, 22:52
Chris Marra's Avatar
Chris Marra Chris Marra is offline
The Blue Alliance Staff / 177 Alum
no team (TBA / Bobcat Robotics)
Chris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond repute
4fx, IIRC, is the company that has been responsible for helping with competition control systems in the past few years since they stopped contracting Hatch Technologies. They wrote the match pairing algorithms and the software used at the regional to handle rankings and brackets, which exports the data to the FIRST website. This might export awards to TIMS, but TIMS is an older system than 4fx, and possibly than Hatch.
Team 177 - Bobcat Robotics
Unread 13-01-2009, 03:05
Nibbles Nibbles is offline
Interstellar Hitchhiker
AKA: Austin Wright
FRC #0498 (Cobra Commanders)
Nibbles is just really niceNibbles is just really niceNibbles is just really niceNibbles is just really niceNibbles is just really nice
I have no problems with PHP 5.2.6 or wget 1.11.4 irrespective of user agent (the user_agent setting and -U argument respectively). (I forgot how much whitespace they use though.) Try again?
Help standardize match data! Use the XML interchange format. (Specification page)
AAA_awright on Freenode IRC chat. (Join us at ##FRC on chat.freenode.net, or in your browser)
[TBA]: Info sent to cell phone... Don Wright The Blue Alliance 12 18-04-2008 20:23
[TBA]: Name/Nickname Update Ran Greg Marra The Blue Alliance 0 21-03-2008 10:00
[TBA]: outdated Team Info in Match Archives adengler The Blue Alliance 5 08-03-2008 14:57
**FIRST** **FVC Team Info** **Important Template Info** Mark McLeod FIRST Tech Challenge 0 21-02-2007 12:41
Update Contact Info TIMS sanddrag Regional Competitions 3 03-10-2002 12:48
