Go to Post Why does 1114 have to be good at everything? ;) - Justin Montois [more]
Unread 10-01-2009, 22:32
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Re: Pivoting shooter ideas
Is your shooter drives going to be horizontal or vertical. If they are horizontal it is easy to feed from the back, top or bottom. You could also save alot of work by turning the robot instead of the shooter.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 14-01-2009, 17:56
fkm300 fkm300 is offline
fkm300 is an unknown quantity at this point
You can cut the id of the 12" Lazy Susan larger but be very careful with the sharp metal. Be careful not to get the metal shavings into the ball race.
When cutting the id, leave the ball race intact.
Shooter motors? StevenB Motors 18 25-05-2006 22:52
side shooter Korbin Robot Showcase 21 14-02-2006 17:23
Pivoting Arm ND4SPDLSC Technical Discussion 4 13-02-2005 10:01
Ball Shooter Squall Kit & Additional Hardware 0 11-01-2005 06:52
Pivoting arm? Jesse General Forum 3 14-01-2004 17:46
