Re: Orbit ball in Inventor
OK, I'm new to Inventor, so I may be doing something wrong, but I can't figure out how to load this file. After saving the attached file on my computer, when I try to load the file, I receive unresolved references... Do other files need to be posted as well, or is there a trick to loading the assembly into Inventor?
He needs to load more files. To open an assembly you have to have the parts. I believe there might be a method of doing it without these parts, but it is easiest just to load all of the parts.
Please put all of the files(.ipt) used to make this model in a folder (zipped) and then upload with the .iam.
You could consider the .iam file as the "assembly" instructions, but without the parts you can't assemble as instructed... ![]() |
ok. these are all the files used in the assembly. i couldnt figure out how to put them in a zipped folder so i just added them all, so if u download them all, it should work. i hope
I have downloaded all the parts and they are in the same folder, but when I try to open the orbitball complete assembly, it asks looks for a orbit ball final assembly. Could you please post this file as well.
A complete assembly of the Inventor ball is at
http://www.3dcontentcentral.com/secu...d=171&id=13546 Select Inventor for Format. Marie |
#7
Here is the file I finally found out how to compress it down os it would fit.
| Inventor Model of Orbit ball? | excel2474 | CAD | 7 | 17-01-2009 11:06 |
| Orbit Ball Containers? | excel2474 | Technical Discussion | 7 | 08-01-2009 15:22 |
| orbit ball transport system | stinkypooman | General Forum | 2 | 06-01-2009 22:45 |
| pic: I spy an Orbit ball | MrForbes | Extra Discussion | 1 | 06-01-2009 22:04 |
| orbit ball supplier? | Gary Dillard | Kit & Additional Hardware | 1 | 03-01-2009 23:03 |
