Go to Post Common sense goes a long way. - Akash Rastogi [more]
Unread 10-01-2009, 23:16
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
pic: Robot-Week1
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
Re: pic: Robot-Week1
Wow, please give some specifics!
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 10-01-2009, 23:41
.999~=1
Well, wide chassis w/ 4 wheel skid steering, all powered. Obviously the drive isn't installed yet.. right now it's on a test robot w/ our electronics guys.
We plan on a conveyor type system to run between those wood panels, and feed the huge hopper (we estimate it holds around 20 balls), then a front panel on the hopper will drop and (the hopper will have an agitator) the balls will drop out...
If you check out http://www.youtube.com/watch?v=Lcjl8nWDzmo at around 0:32 is a little clip of how we plan to coveyor the balls up.
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 10-01-2009, 23:50
NoahTheBoa's Avatar
NoahTheBoa NoahTheBoa is offline
AKA: Noah Tomaszewski
FRC #0968 (RAWC)
NoahTheBoa has a spectacular aura aboutNoahTheBoa has a spectacular aura about
Send a message via AIM to NoahTheBoa
How is the front panel going to drop? You might want to be careful about extending past the bumper perimeter.
Team 968 (Mentor) 2011
Team 1138 (Mentor) 2010
Team 1138 (Student) 2005-2009
Unread 11-01-2009, 00:00
run the trap!!!
Team Role: Human Player
Careful with the hopper....
If you thought poof balls jammed easily... well... have I got a suprise for you
See y'all in Davis!
-Philip J. Fry
.999~=1
Don't worry, we've taken that into consideration... It's probably going to be just like a guillotine like gate, that swings down.
i can't explain it... But just half a half circle that starts up like a n then swings around to the bottom like a u. The top of the u/the bottom of the n is there the bottom of the hopper is... if that makes sense. pivoting around the bottom of the hopper.
Unread 11-01-2009, 01:54
RyanB RyanB is offline
FRC #0360
RyanB is an unknown quantity at this point
I have a question about the tabs sticking out from the hopper, are they to "grab" balls of to sort the out as in a peg board, so they dont get jammed. or if both ideas are wrong what is thier purpose. I like were the direction of the robot is going. Also what kind of rope/ tubeing are you using for the conveyor.
Unread 11-01-2009, 02:03
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
I would suggest putting some kind of large pipe on those thin rods because what ever you use as belting will grip more onto a larger surface and it won't slip on the balls (This breaks the basic idea that surface area doesn't effect friction because the surfaces actually aren't parallel so each point has a separate force, kinda weird but ya)
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 11-01-2009, 02:09
.999~=1
Those are actually just cleco's (spelling?), holding the hopper together until we rivet it all tight. Hehe.
Some 1" surgical tubing from McMaster has been ordered... We've used it with success.
Planning on it... If we had everything done in the picture what would we do with the other 5 weeks! (plus 40 pounds to build whatever we want for 3 weeks after that... stupid new rule)
But, we've been joking that I'd post another picture like this after week 5 and it would just show a crate and an empty shop... We all know that won't happen though
Unread 11-01-2009, 03:00
robodude03's Avatar
robodude03 robodude03 is offline
AKA: Rene Haro
FRC #1538 (The Holy Cows)
Team Role: Tactician
robodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond repute
Aww Brad you beat me to the post
Oh BTW our new website has been posted with some other pictures of our bot during week 1. Check us out at:
www.team399.org
Team 1538 - The Holy Cows
2015 Championships - Quality Award sponsored by Motorola
2014 Championships - Media and Technology Innovation Award
2013 Championships - Chairmain's Award Winner and Newton Finalists w/ 217 & 1986
2013 to Present - 1538 Mentor (Digital Media/Strategy)
2004 to 2012 - 399 Mentor/Coach
2000 to 2004 - 399 Driver
Unread 11-01-2009, 10:40
tim_reiher's Avatar
tim_reiher tim_reiher is offline
Cornell 2014!
FRC #0571 (Team Paragon)
tim_reiher is just really nicetim_reiher is just really nicetim_reiher is just really nicetim_reiher is just really nicetim_reiher is just really nice
Send a message via AIM to tim_reiher
How far deep inside your bumper perimeter is that mechanism going to be?
I'm just asking, because I feel you ought to make sure to that that wouldn't have an off chance of being considered a wedge.
You're making good progress, though. Keep at it.
Today's words of advice- "don't try to broach through your finger". Nothing good can really come of it.
Check out our really new website!
Unread 16-01-2009, 08:32
davidfv davidfv is offline
davidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant future
Good progress for Week 2
Well I thought I would beat all you guys to the punch this week...
Check out the Team399 Videos for this week.
http://www.youtube.com/user/cevTV399
http://www.youtube.com/watch?v=isP11...eature=related
Have fun!!!
Davidfv
Mentor/Drive Coach
Unread 16-01-2009, 11:02
techsupport07's Avatar
techsupport07 techsupport07 is offline
FRC #0876 (Thunder Robotics)
techsupport07 is an unknown quantity at this point
Send a message via ICQ to techsupport07
I saw you were using surgical tubing in the video...we used that in 2006 for the poof balls. It worked quite well, except we would have to change the tubing every so often because it would rip or start to rip. We just got some new type of tubuing yesterday that we are going to use...can't remember what it is called, but it has the same effect that the surgical tubing did, but it is much much stronger!
Unread 16-01-2009, 11:44
Lakedaimon's Avatar
Lakedaimon Lakedaimon is offline
FRC #3012 (Spartans)
Lakedaimon is an unknown quantity at this point
This looks a lot taller than 60". Is it?
Firmware is the most expensive thing in the universe. - Jack G. Ganssle
pic: 166's Robot '07 Robot: Gemini Dan Petrovic Robot Showcase 4 20-02-2007 21:41
pic: 233 robot teaser, yep, theres our robot ; ) ducttapedude Extra Discussion 20 15-02-2007 22:02
pic: 1889 Team HAZE's frame (week1) Tytus Gerrish Extra Discussion 8 19-01-2007 02:23
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 09-03-2004 18:27
