Go to Post Then use Newton's handy-dandy 2nd law (Force = mass*acceleration) to solve... - Chris Hibner [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 09-01-2009, 20:35
mahmosh's Avatar
mahmosh mahmosh is offline
FRC #1946
mahmosh is an unknown quantity at this point
help me in LabView code
hello
our team is started to program with labview ... but there is some problems .. we tryed the simple code (tank or arcade) that came with labview ... and we deployed it on our CRIO ... there is no problems everything works well ...
the problem that we don't know how to change something in the code ... for example ... add more victors and more than 1 joystick ...
is there someone could help ?? or give me guide how to change something in the code and how to add something ??!!!
i am still begainer ... and if we didn't learnt labview we have to go windriver ... but i hate c/c++ programing ... so please help rapidly
Unread 09-01-2009, 22:22
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Re: help me in LabView code
http://www.usfirst.org/community/frc....aspx?id=10934
There's some guides and help under Software Documentation. It should help you get started.
Getting Started with LabVIEW for FRC
LabVIEW Robotics Programming Guide for FRC
LabVIEW FRC Help Document
Using the LabVIEW FRC Framework
If you have any questions don't hesitate to ask.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 10-01-2009, 13:00
darist darist is offline
AKA: David Aristizabal
darist is an unknown quantity at this point
Hi there!
I would also recommend looking at the stuff that NI has put together for us:
http://www.ni.com/first
In particular take a look at the FRC Getting Started Tutorials, here's a link:
http://decibel.ni.com/content/docs/DOC-2511
I found a lot of that stuff pretty good. There is certainly a lot of material there. Here are a couple of the things I found particularly helpful in understanding how things work and how to modify the defaul code (or "framework") that came with the DVD.
- The "Robotics Library" video
- The "Using Framework" document
are probably good places to start
Also take a look at the "Basic Motor Control"
That should keep you busy for a few hours, but they should be well worth it.
One last thing, if you are totally confused by the concepts of VI's, front panel, block diagram, while loop, wires, terminals, etc (all the LabVIEW terminology), then you may want to go through the
Getting Started with NI LabVIEW tutorials. Here's a link:
http://zone.ni.com/devzone/cda/tut/p/id/7466
These tutorials have nice videos and exercises that make them easy to follow, but keep in mind that these are designed for learning LabVIEW in general (so the examples are not designed for the FRC cRIO robot controller).
I hope this stuff helps...
Good luck!
David A
Unread 11-01-2009, 00:18
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
The tutorials the Ben has on his site are really great.
http://www.lvmastery.com/tipjar2008
Some are general LabView and some are directed specifically at FRC.
Posting LabView Code Easily? Greg Marra NI LabVIEW 17 25-11-2009 16:49
LabVIEW Error Code 1055? Vince FRC Control System 11 29-11-2008 09:32
Team 39, 2008 LabVIEW Beta Code BornaE General Forum 17 10-10-2008 17:21
Configuring Labview code to easyC team877 LabView and Data Acquisition 6 16-01-2007 09:21
LabView Gear Tooth Sensor Code SkiRacer LabView and Data Acquisition 2 17-01-2006 03:53
