Go to Post adulthood is overrated. people just give you wierd looks when you play with your transformers, nerf guns and lightsabres. - Tytus Gerrish [more]
Unread 11-01-2009, 02:25
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: Wireless Connection Problem
Originally Posted by Russ Beavis View Post
lynca,
Are you intentionally trying to use your laptop's WiFi radio? Why not disable your laptop's radio and hard-connect to the DS's router? That is, I believe, the technique that FIRST intended.
Considering the control system's configuration, maybe there is some difficulty associated with having 3 wireless radios trying to share (eg the system is intended to be ad hoc and not point-to-multipoint).
Russ
Even when my laptop is connected over ethernet, the system has similar connection issues.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Wireless problem - losing communication jalburty FRC Control System 9 09-01-2009 07:35
Wireless Programming FRC4ME Programming 14 14-04-2008 00:22
problem with connection seanl Programming 1 29-01-2007 10:41
USB DAQ Wireless connection? StevenB National Instruments LabVIEW and Data Acquisition 1 01-01-2006 03:49
Wireless Connection on Pocket PC - AEGIS and Odyssey sanddrag IT / Communications 2 07-01-2005 15:51
