Go to Post See what you don't understand about us students is that we don't know when to stop. - ehfeinberg [more]
Unread 11-01-2009, 01:58
zrop zrop is offline
FRC #2526
zrop has a spectacular aura aboutzrop has a spectacular aura aboutzrop has a spectacular aura about
Team 2526 - Propeller Propulsion Prototype.
Vid:
http://uk.youtube.com/watch?v=Dbi4zbcp3wE
Tell me if you want some specs. or whatnot.
Unread 11-01-2009, 02:09
spc295 spc295 is offline
FRC #0295 (Renevatio)
spc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to behold
Re: Team 2526 - Propeller Propulsion Prototype.
try a condensor fan from an airconditioner, works great
295 Team Captain
Unread 11-01-2009, 02:11
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Have you tested to see if it (or 4 of them) can generate enough force to move your robot?
Unread 11-01-2009, 02:16
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Have you measured the thrust this produces?
Unread 11-01-2009, 02:23
FRC #2526
If you noticed, those fans remain stationary. Their high pitch allows them to push a lot of air, yet have minimal thrust because of all the stalling. I'm pretty sure it wouldn't be a good idea. We're currently running 12.25 - 3.75 plane props which at meant for maximum thurst.
Can some other team argue that this interferes with their robot's movement? Just curious.
If it has enough thrust to have any effect on your robot, then why not on the robot in front of you?
Anyone?
Unread 11-01-2009, 02:24
FRC #2526
Not yet, we haven't had time to make a rig to measure it, or obtain a newton meter for that matter =/
Unread 11-01-2009, 02:25
FRC #2526
Anyone?
If you say that, then perhaps bumping into other robots should be illegal?
Anyone?
=P
Unread 11-01-2009, 02:26
Anyone?
=P
Umm that wasn't a hit at your design
It was a serious question.
Unread 11-01-2009, 02:29
NoahTheBoa's Avatar
NoahTheBoa NoahTheBoa is offline
AKA: Noah Tomaszewski
FRC #0968 (RAWC)
NoahTheBoa has a spectacular aura aboutNoahTheBoa has a spectacular aura about
Send a message via AIM to NoahTheBoa
Anyone?
You probably could argue that it interferes with your robots movement, but IIRC there's no rule that says interfering with another robots movement is illegal. So, arguing that it interferes with you would be irrelevant.
Team 968 (Mentor) 2011
Team 1138 (Mentor) 2010
Team 1138 (Student) 2005-2009
Unread 11-01-2009, 02:30
FRC #2526
Yeah i know, but i don't see why it would be any different from physical contact such as bumping and throwing balls at each other.
I mean, it is part of our plan to abuse the fact that we might be able to blow balls away from our trailer, but really, nothings stopping any other team from making a fan, right? =)
Unread 11-01-2009, 02:35
FRC #2526
Watch how you respond to posts.....
Wrong tone? Do i sound bitter or sarcastic or something? Sorry XD
Unread 11-01-2009, 02:48
Neo97's Avatar
Neo97 Neo97 is offline
FRC #2526
Neo97 is an unknown quantity at this point
I think he's mainly referring to the word "abuse." So in other words yeah... I think it's you're tone. In other news your "sorry" seemed pretty much sarcastic with your XD at the end of it lol.
Unread 11-01-2009, 03:01
Just drop it. Its cool.
woot, 1403 post, Cougar Robotics
Unread 11-01-2009, 06:33
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
To return to the original point of the message. Thank you for the demonstration--while you don't have a newton meter avaliabe it is very simple to build something which will have a similar effect. Take a box and suspend it making a pendulum (longer suspension will mean greater accuracy), mount your fan set up on it and let her rip. By measuring the angle off normal created when your fan is turned on and using a simple bathroom scale to measure the mass of the box and your fan set up you will have more than enough accuracy. Here's the math:
Fractional force of gravity pointing in the horizontal direction: Fgx
Force due to gravity: Fg
Angle created by string from normal: theta
Fgx=Fgsin(theta) By inspection
Fprop=Fgsin(theta)
Note that this lets you give a force in Lbs which are much nicer than newtons.
pic: FRC 2008, Team 2526 Initial Design RyanJK Extra Discussion 2 05-05-2008 18:51
Official Team 2526 Robot Model!! RyanJK Technical Discussion 30 25-01-2008 10:27
Propeller Microcontroller Adam Y. Electrical 4 20-04-2006 13:27
Helicopter propulsion archiver 2001 20 23-06-2002 22:59
