Go to Post "Wow, smells like... physics" - Anna B. [more]
Unread 10-01-2009, 22:56
Joe Finkel Joe Finkel is offline
FRC #0369 (High Voltage)
Joe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura about
Goig "wide" with the chassis
I like to know what is the teams opinion on pros(and one
of them is in update #2 drawing) and cons going wide.
We started our frame but debating.
Unread 10-01-2009, 23:28
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Goig "wide" with the chassis
Pro - you get double width to pick up a ball.
Con - you can't squeeze through smaller spaces.
Pro - 4 wheel wide turns itself more easily (fewer wheels, etc) shorter chains.
Con - short front to rear wheelbase on wide means it can rock at times.
Unread 10-01-2009, 23:52
SWIM's Avatar
SWIM SWIM is offline
SomeoneWhoIsntMe
AKA: James Meintjes
SWIM is just really niceSWIM is just really niceSWIM is just really niceSWIM is just really niceSWIM is just really nice
Unlikely, this year the 'bots will slide before they tip, unless they're incredibly top-heavy.
A wide body can effect the packaging for a shooter / ball storage, and reduce the amount of useful space for a hopper, depending on how you design all that.
Unread 10-01-2009, 23:55
Hanna2325's Avatar
Hanna2325 Hanna2325 is offline
Programmer/Driver
AKA: Hannah
FRC #2177 (Robettes)
Team Role: Driver
Hanna2325 will become famous soon enoughHanna2325 will become famous soon enough
Send a message via AIM to Hanna2325
I think the wide is going to be important with control on the slippery surface, but it also means it would be easier to bump into things driving forward. Also if you are planning to bring balls in from front or back or have a wide storing device it gives you space.
that light is NOT yellow, its orange! Where is the yellow light?
:1..2...3...BEAST!:
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
The trailer also helps prevent any back and forth wobble
Unread 11-01-2009, 00:00
All I can say is Do It.
You'll enjoy the results.
Unread 11-01-2009, 00:18
Gdeaver Gdeaver is online now
FRC #1640
If your main goal is to pick up balls from the floor, then going wide is the logical choice. Turning with 4 wheel tank drive is better. However, keep in mind just how difficult and time consuming chasing down balls can be.
Unread 11-01-2009, 03:33
GarrettF2395's Avatar
GarrettF2395 GarrettF2395 is offline
AKA: Sierra 117
FRC #2395
Team Role: RoboCoach
GarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of light
Send a message via Yahoo to GarrettF2395
The only thing I would be worried about with having a wide chassis is, the possibility of being more maneuverable then is necessary.
I haven't run the numbers on this but, the wide wheel base combined with the low friction surface may cause a "widebot" to slide more while performing a turn.
However, I do think it is one of the top chassis designs for this game.
Not necessarily the best, but by no means the worst either.
https://twitter.com/TeamNinjaMunkee
FRC 2395: Team captain 2008-2009, Design mentor 2010-2011, Lead design and strategy mentor 2012-Present
Unread 11-01-2009, 07:56
slocynerd's Avatar
slocynerd slocynerd is offline
Slocs
AKA: Sunshine
FRC #1517 (The lumberjacks)
slocynerd is an unknown quantity at this point
Also, consider this: the trailer in the back acts as almost an extension to the base of your robot, making sideways a more logical decision because it will take an incredible amount of force (not seen in any first event btw) to knock it clean over.
"The wise speak only of what they know."
"If more of us valued food and cheer and song above hoarded gold, it would be a merrier world." -J.R.R. Tolkien
Unread 11-01-2009, 11:39
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Be careful how far you take that assumption. While the trailer does give you some down-force at the trailer hitch, and some lateral stability based on which side it might currently be Jack-Knifing ...
The end of the trailer tongue has a circular fitting in the square steel rod. It can rotate along this circular piece and NOT transfer rotational forces to the 'bot.
In other words, when/if the trailer ever tips completely over, the 'bot will not feel the rotational tipping forces at all.
[edit] Take a close look at the trailer drawing (GE-09000), page 3. The Trailer Tongue (Item #5, GE-09009), and the Hitch Swivel (Item #19, GE-09036)
[edit2] Then take a CLOSER look (as I apparently did NOT), and notice Item #50 clearly pinning that Hitch Swivel. ...and then disregard my mis-informed advice above. Sigh. I'm 0 for 2 this weekend. Maybe I'll start lurking instead of posting.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Last edited by Ziaholic : 11-01-2009 at 12:17. Reason: added some reference info ... then added a retraction
Unread 11-01-2009, 11:52
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
The round stub is pinned to the square tube in the Trailer Hitch. They do not rotate relative to each other.
-dave
Unread 11-01-2009, 11:57
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
That's a last minute (12/29) design change?
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: Going "wide" with the chassis
Here is a video of our wide robot test:
http://www.youtube.com/watch?v=6HEE_isM0Uo
Phil Malone
http://www.GEARSinc.org
Unread 11-01-2009, 15:37
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I decided that my team should go with a wide base this year the Monday after kick-off and it seems like my decision is paying off. It's main advantage in my opinion is that it'll be less prone to have trouble turning and overturning and should have a wider opening to gather balls. (I've currently designed it to have about a 23-3/4" opening)
-Dustin Benedict
Unread 11-01-2009, 15:49
Daniel885 Daniel885 is offline
FRC #0885
Daniel885 is an unknown quantity at this point
We decided to mount our wheels in the wide position
Pro: Even with the wheels and slippery surfaces it is still easy for even rookies to control.
Pro: Ball capture is not difficult
Con: Increases chance of collision and jams.
Pitfalls of having a "wide" robot? wilsonmw04 Technical Discussion 9 22-01-2008 13:01
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
Congratulations is spelled with a "T" and not a "D"!! Elgin Clock Thanks and/or Congrats 55 09-03-2007 13:24
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
