Go to Post I don't think Brandon is actually doing this, I think he has CD-47 Bot and Archiver locked in a closet doing all this while he has fun - Mike Schroeder [more]
Unread 11-01-2009, 01:49
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
Poly Cord / rubber roller tubes?
Hey,
So i know it as poly cord, but im not sure if that is the correct name. It is colorful plastic cord about 1/4 dia. I know a bunch of teams used this in 2006 (ie 1114 and 111) to transport balls. My team hasnt ever used it but I would like some input on good sources to order from.
Also I'm pretty sure it can be bought in pre-determined lengths (already in a loop) or in a spool where you connect the two ends. My team is debating over which is better or even if these are two options. I'd love some feed back from teams that have used this stuff in the past. Maybe links to good places to find it.
Thanks in advance
Mens et Manus
Unread 11-01-2009, 01:58
NoahTheBoa's Avatar
NoahTheBoa NoahTheBoa is offline
AKA: Noah Tomaszewski
FRC #0968 (RAWC)
NoahTheBoa has a spectacular aura aboutNoahTheBoa has a spectacular aura about
Send a message via AIM to NoahTheBoa
Re: Poly Cord / rubber roller tubes?
You can probably find polycord at mcmaster-carr. As for loop vs. spool, I think spool is better because you can get an exact length that you need that they may not have in a pre-formed loop. I doubt that there is any performance difference between the two options though.
Team 968 (Mentor) 2011
Team 1138 (Mentor) 2010
Team 1138 (Student) 2005-2009
Unread 11-01-2009, 02:04
KF987 KF987 is offline
AKA: Keaton
FRC #2034 (IncrediBULLS)
KF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud of
Send a message via AIM to KF987
If you search "poly cord" on mcmaster's website it should bring it right up.
-Keaton
Unread 11-01-2009, 02:11
Asa's Avatar
Asa Asa is offline
VP
FRC #2102 (Team Paradox)
Asa is an unknown quantity at this point
We have been playing with polyurethane chords for the last couple of days, they have great grip on the balls and are really easy to work with.
To join lengths of it we cut the two ends at an angle to increase the surface area of the joint, and melt them together with an oxy acetylene jewelry torch. I'm sure a retired soldering iron would do the trick as well.
___
Asa
Unread 11-01-2009, 06:37
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Other teams from 2006 mentioned melting the poly cord using a lighter and achieving excellent results. Here is a similar thread which may answer many of your questions:
http://www.chiefdelphi.com/forums/sh...light=polycord
Unread 11-01-2009, 13:41
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
is polycord similar to grip of surgical tubing?
Faridodin "Fredi" Lajvardi KD7WKD
Unread 11-01-2009, 13:48
AdamHeard's Avatar
Lead Mentor
I would say surgical tubing is grippier, but it stretches substantially more. It also isn't near as durable. A system made with surgical tubing may be cheaper at first, but I imagine a very nice surgical tube system couldn't perform on par with a very nice round belt system. I've also heard of several teams who's 06 robots are still running with the original belts, something that would never happen with surgical tubing.
[FTC]: Lego Motor Extension Cord? ttldomination FIRST Tech Challenge 2 11-01-2009 11:52
New Team to be (Possibly) Started at Cal Poly Pomona A. Leese Starting New Teams 13 10-03-2005 01:51
Gum Rubber Brawler006 Technical Discussion 8 12-02-2004 07:57
sheet rubber Adams High Man OCCRA 1 20-10-2002 10:07
Rubber Treads Anyone? archiver 2000 10 24-06-2002 00:29
