Go to Post Honestly though, having a cave would be one of the greatest places to build a robot. There's already lack of light and lots of floor space! Well, if you have a good cave sponsor, that is. - Bryce Clegg [more]
Unread 10-01-2009, 18:23
mahmosh's Avatar
mahmosh mahmosh is offline
FRC #1946
mahmosh is an unknown quantity at this point
it seems there is no program in crio after downloading
hello ...
we tryed to download the project (simple template that comes with windriver) it succeed but it seems there is no program in the crio and the control system flashing... the driverstation show battery: "no code" ... we restarted the crio and the driver station .. so the problem dosen't change.
please need ur help!!
Unread 10-01-2009, 21:08
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: it seems there is no program in crio after downloading
Make sure you have (a) undeployed the default code, and (b) You have clicked "Automatically attach spawned kernel tasks" in the debug options. You can check the kernel task list to see if there is already an FRC_RobotTask in there (which happens to be the task that gets started by default).
Unread 11-01-2009, 07:50
mahmosh's Avatar
FRC #1946
i will try this when debuging .... but when i download the project by FIRST downloader why it doesn't success
Unread 11-01-2009, 08:54
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Did you set the downloader preferences?
Window>Prefrences:>FIRST Download Options
Unread 11-01-2009, 09:02
mahmosh's Avatar
FRC #1946
no .. we didn't ... i don't have the program here .. could u send me a picture for that windows and what options should i make
Unread 11-01-2009, 09:30
AKA: Brad
#0190 ( Gompei and the Herd)
Look at the menu: Window / Prefences, then the FIRST Downloader Preferences tab. Fill in your team number (that sets the IP address) and the .OUT file name. The .OUT file will be in the c:\windriver\workspace\<project-name>\PPC603gnu_debug directory. After that you should be able to download the project.
Remember, you only have to download it when you want it to start at power up of the cRIO. If you are debugging use the "Debug Kernel Task" option.
Brad Miller
Robotics Resource Center
Unread 11-01-2009, 09:32
byteit101's Avatar
I dont have it here either, but attached is a quick rendering of what it should look like (yes, i just did it in Visual Studio Designer)
Name:	FRC dowload demo.PNG
Unread 11-01-2009, 10:33
mahmosh's Avatar
FRC #1946
thank you alot i will try it ... do u think it may fix the problem ??
Unread 11-01-2009, 17:58
Adamsmasher23 Adamsmasher23 is offline
FRC #1646 (Precision Guessworks)
Adamsmasher23 is an unknown quantity at this point
We had this same issue, and resolved it by specifically pointing to the WPILib.a file in the project Build Options.
Unread 11-01-2009, 18:28
mahmosh's Avatar
FRC #1946
can u give me a picture for the project build options that u mean .... cuase i don't remember how to get it ...
Unread 12-01-2009, 11:46
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
You will also get "No Code" when you load a program that has unresolved symbols. You can see if this is your problem by hooking up the serial console and watching the cRIO load your program as it boots up. It will print messages telling you which symbols remain unresolved.
Unresolved symbols occur when your program calls out to some function or variable that is not defined in your code (for example, saying a class has some member function in its definition, but then never actually implementing the function).
The serial console has proved extremely helpful for us in resolving most code download issues.
Originally Posted by mahmosh View Post
hello ...
Unread 12-01-2009, 17:27
I don't have the development computer available to me right now, but from memory:
Project menu>Preferences
then click on (I think) Build Preferences
Then click on the Libraries tab
and add WPILib.a as a fully qualified library file
Or at least that was what fixed our problem.
And yeah this is related to unresolved symbols.
Unread 12-01-2009, 18:53
mahmosh's Avatar
FRC #1946
it does work after updating windriver thx all
Problem Downloading Program from WindRiver to Driver Station The_Laughing_ManMII C/C++ 10 09-01-2009 20:03
Help with 2009 wiring/program downloading programmr FRC Control System 5 17-12-2008 21:57
KOP Gyro seems to run-on after turn stops PhilBot Control System 8 05-03-2007 12:43
Downloading the DEfault program gjibben Programming 1 11-02-2004 21:20
I Need Help with downloading Basic Stamp Program archiver 1999 2 23-06-2002 21:57
