Go to Post The 2008 team is not the 2007 team and won't be the 2009 team. Every year is a new year and a new opportunity for growth and development as a FIRST team. It's very cool. - JaneYoung [more]
Unread 11-01-2009, 14:41
dudefromjapan dudefromjapan is offline
Driver/Electrical Team
FRC #2496 (Team TruBlu)
Team Role: Electrical
dudefromjapan is on a distinguished road
Making belt loops with vinyl tubing
Our team is trying to make belt loops out of vinyl tubing. Anybody know the most secure way connecting the ends of the tubing? Thanks in advance
Unread 11-01-2009, 14:57
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Making belt loops with vinyl tubing
I'm no expert on the subject but you should be able to take the ends of the tubes and melt them together with a heat gun or soldering iron. If you could post up the link or a picture of the product you might get more answers.
-Dustin Benedict
Unread 11-01-2009, 15:03
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
That would help- I'm having some trouble visualizing.
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 11-01-2009, 17:40
Here's a picture of basically what we're using.
I tried the melting technique thefro526 proposed. It worked quite well. Anybody else have ideas as well?
Last edited by dudefromjapan : 11-01-2009 at 17:41. Reason: Image used before was HUGE XD
Unread 11-01-2009, 17:49
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
Mcmaster says that there are two ways to do it. One is to melt the ends together by cutting a 45˚ angle such that you have a large surface area to combine. Just make the ends soft and melted with a heat source. (heat gun, soldering iron, lighter, torch etc) then combine using a scrap piece of angle as a guide for straightness. Or you can cut it without an angle and buy these barbed sticks which you insert into both. search "multi-barbed tube fittings " on Mcmaster.com
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 11-01-2009, 18:02
Zyrano Zyrano is offline
AKA: Alvin
FRC #1967
Zyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to behold
Send a message via AIM to Zyrano
Do a search on Mcmaster for hollow tube round belting, they use a simple gromet and holds the material together very well. We've used them in the pass without a problem. Just cut to lenght and press them together.
W.R.R.F. Board member, 2007-??
Mentor, 2007-??, NDSJ Robotics FRC Team 1967
Mentor, 2013-15 Evasive Robotics FTC Team 6223
Supporter, 2006-11, Bulldogs Robotics FRC Team 581
Supporter, 2007-??, Pioneer HS Robotics FRC Team 668
Supporter, 2011-??, Dark Matter FRC Team 2643
Student, 1999- GRT FRC Team 192
Unread 11-01-2009, 18:47
Thanks for the useful input. I'll be looking into these solutions soon.
Code error with while loops?? Lakeeffect1674 Programming 6 09-03-2008 13:19
Fun with Bosch Tubing computerboi1503 Chit-Chat 1 09-02-2008 19:33
Possible to do multi-speed transmission with v-belt? Squirrelrock Motors 15 13-12-2005 14:44
problems with pneumatic tubing in telescoping arm johnnymac4545 Pneumatics 5 25-02-2005 11:19
Making money with your site Sam Oldak Website Design/Showcase 11 31-03-2004 10:03
