Go to Post I walk through the door, and suddenly the field breaks down. It must be my magnetic personality. - Swan217 [more]
Unread 11-01-2009, 12:46
sagivlev sagivlev is offline
FRC #1943
sagivlev is an unknown quantity at this point
Problem with vision assistant
hi
I used the guide for image processing in NI's website
(the one which teaches you how to locate the color of a marker cap)
and when I tried to convert the things in the vision assistant to a VI,
the VI didn't have an error in.
I want to know how to add it.
thank you, Sagiv.
Unread 11-01-2009, 15:41
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Re: Problem with vision assistant
I did exactly what you did and found the same thing. It took me forever to figure out how to add inputs and outputs to a vi. For the error, right-click the unbundle that's set to "Code" and create a control.
Next you have to switch to the front pane, then right-click the icon of the vi and select "Show Connector". You'll see a diagram where the icon was. If you want an input, click on a segment to the left, then click on the control you want, in this case the error in. Now when you use that vi, you'll be able to wire in an error. Hope that helps!
Unread 11-01-2009, 16:59
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
I am also trying to add my Vision Assistant's VI to my robot main with no luck.
The above post helped with the error in/out (and other problems I was working on), but I still have no clue what else I need to add controls for.
For example: the ImageDevRef.
What else needs to be done?
Team 2052- KnightKrawler
Mentor and volunteer
Unread 11-01-2009, 19:39
Luke Pike's Avatar
Programmer
FRC #1501 (THRUST)
If you don't have an image in, then you probably didn't export the vi right. When you export, you need to select "Image Control" instead of "Image File" when you are asked to select an image source. If you did that, then you should have an image in and image out that you can wire up when you add it to the vision processing vi.
Unread 11-01-2009, 21:48
AKA: Bryan
Ahh, that would be the problem.
Thanks!
Axis Camera responding in the Vision Assistant but not in WindRiver DanDon C/C++ 3 11-01-2009 12:50
Assistance in Vision Assistant Carmelulu` NI LabVIEW 1 10-01-2009 15:36
stereo vision system with OV7620 steveg Programming 3 04-05-2006 12:40
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
BuzzWriter - PBasic Assistant archiver 2000 0 23-06-2002 22:58
