Go to Post The code won't compile if you violate the rules of the programming language...but English is more robust, it seems to work pretty well no matter how we engineering nerds mangle it! - MrForbes [more]
Unread 11-01-2009, 15:41
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
Gyro wiring?
Our team is trying to hook up the gyro, but we cannot find where to do this. We have looked at the sensor manual with no success. We have search here and on the FIRST forums. I have even looked through the titles of all the threads on the FIRST forums and all the electrical threads here. Any thing having to do with the gyro I have looked at and no one else seems to be having the same problem. Has anyone else hooked up the gyro or know how to do it?
Thanks!
Unread 11-01-2009, 15:58
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Re: Gyro wiring?
You have to hook it up to a pwm cable, and plug it into the analog bumper i believe.
Unread 11-01-2009, 16:22
Re: Gyro wiring?
We know that, but what orientation does the cable go in? Our gyro isn't labled !
Unread 11-01-2009, 18:01
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Re: Gyro wiring?
It doesn't look like this?
From top to bottom it's Signal (white), 5V (red), 0V (black) in the rate column
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 11-01-2009, 19:21
Re: Gyro wiring?
Thanks! Our gyro looks like that but it doesn't say where to attach what as show in the picture.
Unread 11-01-2009, 19:22
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
Re: Gyro wiring?
Thank you for the information. For our reference, since the gyro doesn't have +5V and 0V labeled (as the accelerometer does), how did you know?
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
Unread 11-01-2009, 19:55
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Gyro wiring?
I can't seem to access their website at the moment but if you track down the FRC2009 Competition Manual website, there is a Sensor Manual that goes with Section 8 Robot Rules. I'm fairly certain that the gyro and accelerometer boards' datasheets are included in that document.
Russ
Unread 12-01-2009, 13:58
Re: Gyro wiring?
The document is here
http://www.usfirst.org/uploadedFiles...%20Rev%20B.pdf
There is a little star thing around the signal on the X axis on the accelerometer, just like on the temp on the gyro. If you look at the PCB, the wiring for those holes come from different places instead of being common like the 5V and the 0V.
Help: wiring ADXRS300EB Gyro Eval Boards de_ Sensors 3 18-03-2008 22:21
2003 Gyro Wiring Harness DukesAZ Electrical 3 03-02-2005 18:20
2003 Gyro Wiring Harness DukesAZ Technical Discussion 3 03-02-2005 18:20
wiring Michael Leicht Inventor 2 21-01-2005 15:49
wiring. archiver 2001 1 24-06-2002 00:07
