Go to Post before you post, ask yourself: Is there a good reason to post this? - Jeff Waegelin [more]
Unread 11-01-2009, 16:21
hayleybayley217 hayleybayley217 is offline
AKA: Hayley
FRC #0217 (ThunderChickens)
hayleybayley217 is on a distinguished road
"Pause between auton and tele?"
Has anyone seen any mention of whether there could be the occasional pause between the end of autonomous and the beginning of teleoperated? With the human players being able to throw during auton, if there is a pause, will penalties be dealt to those who continue to throw? Would those balls be removed? And finally, what would happen with those 'airballs' that have been thrown before the buzzer, but score afterwards?
Unread 11-01-2009, 16:35
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
Re: "Pause between auton and tele?"
Traditionally they have had to put a pause between auton and teleop in order to calculate some sort of autonomous bonus. There are no such bonuses this year, so I don't see why they can't go right onto teleop. I suppose there is always that time it takes the drivers to walk up to the controls, though. Maybe they'll be expected to do that during the first few seconds of teleop now. Sounds like a great Q&A question, as I haven't seen anything on this yet.
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 11-01-2009, 16:45
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
Human players can throw game pieces (except supercells) in during autonomous without penalty. From the Q&A, posted by the GDC:
There is nothing in the rules that prohibit the Payload Spec1alists from throwing Moon Rocks during Autonomous.
The autonomous period ends when the clock reaches 0 for autonomous, from section 7:
Game Periods
<G01>
AUTONOMOUS PERIOD - The AUTONOMOUS PERIOD is the 15-second period at the start of the MATCH. PILOT control of the ROBOT is not permitted at this time. During this period, the ROBOTS may react only to sensor inputs and commands programmed into the onboard control system. All ROBOT safety rules are still applicable during the AUTONOMOUS PERIOD. The AUTONOMOUS PERIOD ends when the arena timer displays zero seconds left in the period.
This means the drivers can step forward at this time.
The teleoperated period begins just after the autonomous period ends- from section 7:
<G02>
TELEOPERATED PERIOD – The TELEOPERATED PERIOD is the 2-minute period of game play immediately following the AUTONOMOUS PERIOD. At the beginning of the TELEOPERATED PERIOD the OPERATOR CONSOLE controls are activated and PILOTS may remotely control their ROBOTS. The PILOTS continue to teleoperate their ROBOTS for the remainder of the MATCH. The TELEOPERATED PERIOD ends when the arena timer displays zero seconds. This also indicates the end of the MATCH.
Immediately implies that there is no delay. Also, if the teleoperated period begins immediately, the payload specialists can just continue to throw game pieces, as they are allowed for the duration of the match.
Edit: In response to,
If you are talking about bell signaling the beginning of teleop (=end of autonomous), it makes no difference, because the game simply continues.
If you're talking about the end of the match, from section 7:
<G07>
Scores are determined based on the state of the GAME PIECES at the end of the MATCH.
And from above, the match ends when the clock hits 0, so a ball which falls into a trailer after the clock hits 0 will not count. (Often they later add a clause that scoring is done when all the game pieces have come to their final resting state or the like, so you might want to wait to see if this happens.)
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 11-01-2009, 16:55
AKA: Hayley
The 'immediately' doesn't necessarily say that there will be no pause. The '08 manual uses that as well, but the pauses existed.
Unread 11-01-2009, 18:09
AKA: Ellen McIsaac
It is possible we will still see them. It's hard to tell until Week 1 Regionals roll around.
Generally, as said above, the pauses are because of autonomous bonuses in scoring which need to be calculated. We don't have any of that this year... so I'm guessing no pause.
Ellen McIsaac
Unread 11-01-2009, 18:22
GaryVoshol's Avatar
Cogito ergo arbitro
One of my first thoughts reading through the rules, after, "No auton bonus?", was, "No need to pause before teleop this year."
(since 2004)
Unread 12-01-2009, 09:37
SWIM's Avatar
SWIM SWIM is offline
SomeoneWhoIsntMe
AKA: James Meintjes
SWIM is just really niceSWIM is just really niceSWIM is just really niceSWIM is just really niceSWIM is just really nice
I'm looking forward to a Le Mans start, where the drive team needs to sprint to the controls before they can start driving
Unread 12-01-2009, 09:43
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
well im not thinkin the sprinting to the controls is a good idea. its not safe. ha. but im not sure about the pause.i can see a need for it. and i can also see there being no need. guess it dependson the individual match as it can change
Accurately "Arcing" in Auton/Hybrid Mode kiettyyyy Programming 17 07-04-2008 14:24
Suggestion: Abandon the term "tele-operated" Dave Flowerday General Forum 12 17-04-2007 16:34
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? gnormhurst Programming 3 22-02-2004 02:55
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
