Go to Post Seasons are often made or broken in the first week of build season. 1114 wouldn't be repeatedly giving their strategic design seminar if it wasn't that important. - Knufire [more]
Unread 11-01-2009, 16:34
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
pic: 1726 Lunacy Wood Chassis Design
Unread 11-01-2009, 16:47
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: 1726 Lunacy Wood Chassis Design
This looks awesome. What type of plywood are you planning on using? Also are you using epoxy or wood glue?
Mentor 2415
Unread 11-01-2009, 17:00
GUI GUI is offline
AKA: Gary
We're using birch plywood. The wood will be attached using reular wood glue and staples.
Unread 11-01-2009, 17:29
AKA: Sean
Baltic birch I am assuming? I am looking into wood this year as it seems like I can build a much better frame for this game from wood than aluminum. Now I just need to convince the team that a wood frame can work.
Mentor 2415
Unread 11-01-2009, 17:52
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We'll know in about two months
Unread 11-01-2009, 18:01
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
Cool. Is the front part of the bot open for ball collecting?
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 11-01-2009, 20:31
GUI GUI is offline
AKA: Gary
Yes, the front opening is for ball harvesting. This frame is designed toallow as much room low to the ground as possible for anything that the manipulator might need.
Unread 12-01-2009, 23:51
GUI GUI is offline
AKA: Gary
Small update: we got the frame glued and stapled together today, went pretty quickly. The bare frame (no motors, transmissions, wheels, electronics, anything) weighs 16.4 lbs.
Unread 12-01-2009, 23:54
AKA: Sean
looks awesome! So how strong is it? I can't wait to get ours going together.
Mentor 2415
Unread 13-01-2009, 00:01
GUI GUI is offline
AKA: Gary
We haven't put much weight on it as the glue is still wet, but I expect it will be a little stronger than our pre-season prototype.
pic: Latest on wood-coast chassis Bertman Extra Discussion 24 21-01-2009 12:26
pic: Quick, Affordable Wood Chassis Axle Mount GUI Extra Discussion 10 28-12-2008 10:09
pic: 1726 Pre-Assembled Chassis TheOtherGuy Extra Discussion 4 26-01-2008 11:05
pic: 1726 Overdrive Chassis CAD GUI Extra Discussion 10 23-01-2008 00:07
pic: Team 1726 MegaMaid Motors/Chassis/electronic board yodameister Robot Showcase 3 11-02-2006 01:21
