Go to Post Just remember to be as transparent and inclusive as you can. - DonRotolo [more]
Unread 11-01-2009, 15:41
mahmosh's Avatar
mahmosh mahmosh is offline
FRC #1946
mahmosh is an unknown quantity at this point
what does all these updates??
i want to download all the updates that i need for the windriver:
i entered this link : http://first.wpi.edu/FRC/frcupdates.html
i have alot of updates i read everything but there is alot so i couldn't understand how to install it (i don't know where are my feet) !!!
i see:
1) WorkbenchUpdateV1.2.1562.exe
2) Source code for build 1562. and what are SourceForge server
3) FRCLabVIEWUpdate1.0
4) Beta update 5
5) Source code for beta release
6) FRCNIWRUpdate1.0 (88mb) - do not use this updater for V1.2 or newer of the C/C++ libraries
so what the deffernce between all !!!
Unread 11-01-2009, 15:43
mahmosh's Avatar
FRC #1946
Re: what does all these updates??
if someone could help me how to download all the updates that i need step by step .. please help ...
thanks
Unread 11-01-2009, 17:59
mahmosh's Avatar
FRC #1946
please help me i am waiting
Unread 11-01-2009, 18:03
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Please be patient. I personally can't help you in this regard. I'm not knowledgeable at this sort of thing. However, the best responses come with patience. It might be a couple of days before you get a good answer or it could be 10 minutes. Either way, adding extra posts isn't going to get a response any quicker.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 11-01-2009, 18:08
d235j d235j is offline
FRC #4454
d235j has a spectacular aura aboutd235j has a spectacular aura about
First, install the software from the two DVDs included with the kit (do not change the default directories).
After that, you need to install the FRCLabVIEWUpdate2.0 (clicking on 1.0 will take you to 2.0) [fully unzip it, then install it]; and then run WorkbenchUpdateV1.2.1562.exe.
Just ignore the others (except for the source code for WPILib, you might want to look at that).
After updating, you'll need to re-image the cRIO with the correct software (and don't forget to update the driver station; see http://usfirst.org/community/frc/content.aspx?id=10934).
Unread 11-01-2009, 18:34
mahmosh's Avatar
FRC #1946
thanks for ur help ... i had installed the program and the updates without the manual... i don't know if i made something wrong ... so should i unistall the program and install it again ?
and u said (except for the source code for WPILib, you might want to look at that). what to look for ??? i didn't understand
and i want to tell you that i updated the driverstation.. should i update it again ??!!!
Unread 11-01-2009, 22:48
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Hi mahmosh,
The WPILib source code may be useful to you if you want to see how the libraries work; you don't need to install them.
The driver station update from November is (as far as I know) is the most recent one; you shouldn't need to update it again right now.
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 12-01-2009, 18:54
mahmosh's Avatar
FRC #1946
thaaaaaaaaaaaaaaaaaaaaaaaanks alot
you helped me .. i downloaded all the updates and it does work well and everything is ok ...
Does anyone know of crimpers like these? Michael Hill Electrical 14 27-11-2006 16:12
What to do with all these poof balls? efoote868 Rumor Mill 64 18-04-2006 17:09
[FVG]: Anyone Interested in Getting Updates? (TO ALL CDers) Dorienne FIRST-related Organizations 8 02-01-2005 15:24
All these time multipliers.... archiver 2001 0 24-06-2002 02:53
all these rumbles archiver 2000 2 23-06-2002 22:49
