Go to Post These are words on a computer screen, please stop giving the text on this screen such incredible power over how you feel. - Stephen Kowski [more]
Unread 10-01-2009, 12:59
Robot-pineapple's Avatar
Robot-pineapple Robot-pineapple is offline
FRC #2423 (Kwarqs)
Team Role: Electrical
Robot-pineapple is an unknown quantity at this point
Possible camera problem?
Has anyone had this problem?
We can acquire single pictures with our camera, but we can't take a sequence of frames. When we try to take a sequence, the only option we have is to set the number of frames (none of the other options that are described in the NI manual). To run these tests we are using Vision Assistant 8.6. The program says we've acquired a sequence of images, but they're all blank (the frames are all black).
Any ideas? Is this a defective camera, defective software, etc?
Unread 10-01-2009, 13:25
suj's Avatar
suj suj is offline
Alumni/PartTime-Mentor on Team 1219
AKA: Sujeethan Vishnumoorthy
FRC #1219 (Iron Eagles)
suj is an unknown quantity at this point
Send a message via MSN to suj
Re: Possible camera problem?
i haven't actualy tried it but by looking at it, it seems legit and it's by first so if you have any issues make a comlaint about you're kit
Programming Captain: 09/09 - 06/12
Drive Team: 2011-2012
Mentor: Sept 2012
Admin of the Team 1219 Facebook page: https://www.facebook.com/Team1219
http://i46.tinypic.com/i52els.jpg
Unread 11-01-2009, 18:39
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Is there really a reason to do this?
If I recall correctly ours does this to with getting series, but we just opted for the "let's not do that" approach. We get a couple frames to work the algos, then we put it into labview.
Then we get to use it with a live camera, (with great success so far).
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 11-01-2009, 18:43
Hanna2325's Avatar
Hanna2325 Hanna2325 is offline
Programmer/Driver
AKA: Hannah
FRC #2177 (Robettes)
Team Role: Driver
Hanna2325 will become famous soon enoughHanna2325 will become famous soon enough
Send a message via AIM to Hanna2325
We were having some problems earlier in the week where it would all freeze up for a bit...then we did some stuff that had nothing to do with the camera and next thing u kno it is working (well i think thats how it went)
that light is NOT yellow, its orange! Where is the yellow light?
:1..2...3...BEAST!:
Unread 12-01-2009, 10:41
Mike Bennett Mike Bennett is offline
FRC #1918
Mike Bennett is an unknown quantity at this point
My problem is sort of the opposite.
I can not acquire any images from the camera when using Vision Assistant.
I get the following message:
Error 56 occurred at TCP Open Connection in Read Axis JPG.vi->IVA Axis IP IMAQ Exec.vi->IVA Axis IP IMAQ Interface.vi->IVA Call Process Module Interface.vi:2->IVA Acquisition Tools Palette.vi
Can someone help me? Please.
Unread 12-01-2009, 13:33
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
put a probe on the image output in "vision processing.vi" and save the image that you get back.
When the camera is connected to the RIO, your computer CANNOT see it.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 13-01-2009, 09:00
When attaching the camera directly to the PC, you have to match the IP address ranges. I usually change the PC IP address manually to 192.168.0.91 or something similar, but not 90.
Don't forget to change it back to 10... when hooking to the robot.
Greg McKaskle
Possible Problem!? Gabriel Mendez General Forum 20 06-01-2008 01:30
Possible phpBB problem JohnBoucher IT / Communications 1 11-12-2004 21:17
Pneumatics Problem + possible fix Srkasner Pneumatics 4 24-02-2004 10:39
Possible seeding problem at regionals archiver 2001 10 23-06-2002 22:25
Possible Wire Problem? D.J. Fluck Kit & Additional Hardware 2 17-02-2002 03:28
