Go to Post Sometimes it's not what you know going into a battle, but who you know. - Elgin Clock [more]
Unread 10-01-2009, 22:21
EncodersRUS's Avatar
EncodersRUS EncodersRUS is offline
Zombie repelant in human shape!
AKA: Tom Hewson
FRC #2550 (OCPRO)
EncodersRUS is an unknown quantity at this point
Send a message via Yahoo to EncodersRUS
Question Encoders and Rover Wheels
Can we attach the encoders to a rover wheel and still get an accurate measurement? Or will we have to add slippage to our code to make up for any sliding that may occur?
The ultimate fight:
LabVIEW Programming versus people who think rationally...
LabVIEW Junkie and 2011 OCPRO Mentor
Unread 10-01-2009, 22:25
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Re: Encoders and Rover Wheels
I think a lot of teams are planning on doing some sort of idle wheel in the middle of their bot for an encoder of some sort, there's a lot of questions in the Q&A about it and all of them have said this is legal.
Another thought about encoders that I know my team plans on using is using them in sync with an accelerometer and making traction control
Unread 10-01-2009, 23:03
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
The only ting we're using encoders for is detecting slipping wheels. The actual navigation is being handled by a combination of vision processing(for obstacle avoidance) and inertial nav(for absolute position)
Get yer robot source code here!
Unread 10-01-2009, 23:31
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Plain and simple, if you put an encoder an a drive wheel and it slips, the encoder reading will be inaccurate. It's next to impossible to just throw code at it to deal with slippage.
If you're dead set on using encoders to measure robot velocity and distances and etc, then it's best to put the encoder on a nondrive wheel that will be pulled along with the bot. If the bot rolls, the wheel rolls, the encoder gets an accurate count.
If the bot doesn't roll, the wheel doesn't roll, the encoder still gets an accurate count. This means it doesn't matter if the drive wheels are slipping.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 11-01-2009, 12:43
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
In direct answer, yes, if the wheels slip then the encoder will be wrong. An encoder measures a number of revolutions, and has no way of "knowing" how much traction a wheel has. For traction control, you could look at either an idle wheel, current sensors on the motors, or an accelerometer. Encoders are a good choice to see what the wheels are doing in terms of speed - it will allow comparison to another sensor - and the comparison could provide the slip/no slip info you want.
CRUD Name: Windows
Alumni to Team: 350
Unread 11-01-2009, 16:36
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
In this case, would it be legal to use two omniwheels? Would this be considered using items other than the rover wheels for traction, even if they are designed not to mechanically affect the slippage or traction of the robot?
-- Marshal Horn
Unread 11-01-2009, 16:47
Andy L's Avatar
FRC #1458
Check the Q&A for this, there is a large amount of posts on that, but in general they say it is ok but provide more specifics than just that
Unread 11-01-2009, 18:31
AKA: Tom Hewson
FRC #2550 (OCPRO)
Thumbs up Re: Encoders and Rover Wheels
Thank you for all of your input and suggestions. I will approach our legal dept. tommorow to see exactly what wheela we can use but will probably end up listening to mechanical. Thanks!
The ultimate fight:
Unread 11-01-2009, 18:41
Kahn! Kahn! is offline
FRC #1379
Kahn! is an unknown quantity at this point
We had the same idea. Using an undriven wheel with an encoder would provide a measurement to where your robot is moving, but I don't believe you would be able to translate that into a form of traction control without more data.
Unread 11-01-2009, 18:50
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Could you elaborate on what you mean by internal nav?
Unread 11-01-2009, 19:40
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
I believe it means the robot is recording its positional coordinates internally, and these coordinates correspond to a certain point on the field.
-- Marshal Horn
Unread 11-01-2009, 23:05
Nathan used the word "inertial", not "internal". Inertial navigation uses accelerometers and yaw rate sensors to figure out where the robot is based on where it was when it was reset/calibrated and what accelerations it has been subject to.
Unread 12-01-2009, 09:26
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
FYI
http://forums.usfirst.org/showthread.php?t=10963
Unread 12-01-2009, 11:46
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
In 2004 we built an omni-wheeled robot and included a pair of small, plastic, rover omni-wheels to measure x and y chassis movement on the field. The results were mixed. In the end, we decided that those plastic wheels were, sometimes, slipping on the carpet. This year we're going to include one rover wheel. But, right now the plan is to use a wheel material with some grip.
Don't PANIC!
S. P. A. M.
Unread 12-01-2009, 12:34
Freeztech's Avatar
Freeztech Freeztech is offline
FRC #0401 (Hokie Guard)
Team Role: Electrical
Freeztech is an unknown quantity at this point
yeah, my team was thinking about that, this would allow you to have a comparison between what your robot is doing and what it thinks its doing, allowing you to work this into an automatic acceleration code. because of how tricky the acceleration is going to be, this would help out loads.
Dubito, egro Cogito, egro sum.
Rover Wheels neoshaakti Kit & Additional Hardware 11 09-01-2009 14:34
Cost of Rover Wheels Boco Gear General Forum 3 08-01-2009 16:10
New wheels / floor and encoders for position. martin417 Technical Discussion 29 08-01-2009 07:19
4 encoders + mecanum wheels programing Smoking_Gun Programming 4 18-01-2007 23:43
