Go to Post It is much harder for someone to misuse the labor you do than it is for them to misuse of the dollar you pledge... - IKE [more]
Unread 11-01-2009, 18:42
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Detecting trailer position
Due to the differences in maneuverability when the trailer is at different positions, I realized that some sensor to determine what angle the trailer is at could be quite useful. However, being unable to modify the trailer, and the trailer hitch being outside the maximum robot dimensions, I was unsure of how to do this.
Any suggestions?
(I was considering using SONAR on one side, but I wanted to know if there was a better way)
-- Marshal Horn
Unread 11-01-2009, 18:51
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Detecting trailer position
Your camera can detect trailer position relative to your robot easily. Unless you are using it for something else
Unread 11-01-2009, 19:06
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Of course, that's always the problem.
Unless I find it beneficial to have the turret pointed at the trailer the whole time, I'll be using the camera to aim the turret.
-- Marshal Horn
Unread 11-01-2009, 22:15
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Using an ultra-sonic was the first thing that cam to my mind.
Unread 11-01-2009, 22:26
popnbrown's Avatar
popnbrown popnbrown is offline
FIRST 5125 HOTH Lead Mentor
AKA: Sravan S
FRC #5125 (Hawks on the Horizon)
popnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond repute
Using Ultra-Sonic or Sonar would'nt give you the best results however because if a ball flies in the way or if another robot comes, it would block it. I would try to put something say an encoder and connect it inside the trailer hitch to the pin.
I am an employee of FIRST. However, the postings on this site are of my own perspective as a FIRST mentor and volunteer and do not necessarily reflect the views of FIRST.
FIRST Team 5125 Hawks on the Horizon Lead Mentor
FRC Team 4096 Ctrl-Z Former Mentor
FTC Team 5203 #19@! Former Mentor
FRC Team 1403 Cougar Robotics Alumni
Unread 11-01-2009, 22:35
Gdeaver Gdeaver is offline
FRC #1640
2 30 cm sharp Ir sensors could do it .
Unread 11-01-2009, 22:42
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
A pair of sharp IR sensors should work well for this.
Unread 11-01-2009, 23:33
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
That's what I'd tend to go with. Maybe have them on servos so that the left one is slightly offset to the left and the right one is slightly offset to the right, so you can tell which way it's moving and track it. It would probably work best to point them at the bar that goes to the trailer hitch, because that's less likely to have a ball fly past it.
Unread 12-01-2009, 10:43
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Originally Posted by kamocat View Post
...I realized that some sensor to determine what angle the trailer is at could be quite useful.
Just curious, what will you do with the trailer position information?
Unread 12-01-2009, 12:42
Freeztech's Avatar
Freeztech Freeztech is offline
FRC #0401 (Hokie Guard)
Team Role: Electrical
Freeztech is an unknown quantity at this point
the problem I see with IR sensors is that you can't attach them to the trailer, unless you though of something I completely missed.
The thing that came to my mind was actually a photocell stuck in the trailer hitch and the angle determines how much light it gets and is based off of that. unless there is a rule saying you can't mount things inside the trailer hitch, I didn't see anything against it.
Dubito, egro Cogito, egro sum.
Unread 12-01-2009, 12:51
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
I was hoping that we would mount the camera far enough back, so that it would cover the majority of the field we could fire in. Position would be detected by change in said objects size. Movement would be calculated after 2 frames, and acceleration in 3 frames. Naturally the later info for acceleration would allow us to figure where the trailer would be in say a couple tenths of a second that it would take the ball to get there, and for a second ball to get there so we could lead enough for say 7 or so balls to reach the trailer. Oh lots of trig to do this. The cRIO can do floating point right?
Is now an engineer thanks to FIRST.
Unread 12-01-2009, 17:19
Joshamuffin Joshamuffin is offline
Programmer
FRC #1723 (FBI)
Joshamuffin will become famous soon enough
Send a message via MSN to Joshamuffin
Put some sort of rotation sensor on the bolt the hitch attatches to or something.
Unread 12-01-2009, 18:44
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Due to the trajectory of the balls, I would estimate half a second to reach a trailer. Unfortunately, this allegedly 30 fps camera seems to have been reduced to 10 fps (frames per second), and with horrible blurring.
Labview has a standard of 64-bit floating point integers (dbl), but there is an option of 32-bit floating point integers (sgl).
I don't believe it is legal to attach anything to the trailer or trailer hitch, as this would likely be outside the allowable limits for the robot. Assuming the trailer hitch tongue is steel, you could possibly use a very strong neodymium magnet on a spring-loaded potentiometer to detect which side it is on. More likely, though, would be looking down the tongue and dealing with reflectivity. I'm rather surprised FIRST didn't allow a reliable way for us to detect this.
-- Marshal Horn
detecting your own alliance(C++) nathanww C/C++ 17 11-01-2009 17:13
Low-Cost trailer drawings? (was: Trailer) DM7000 General Forum 2 07-01-2009 16:54
Detecting Hybrid \ Teleoperated king vash Programming 4 14-07-2008 13:15
Detecting Start of TeleOp Mode Danny Diaz Programming 4 26-02-2008 01:37
detecting life in batteries wkethman Electrical 5 07-03-2006 08:04
