Go to Post I also exclusively use FRC team numbers when punching in times for the microwave. - Calvin Hartley [more]
Unread 11-01-2009, 12:25
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pic: Carmen week1 team 842
Originally Posted by Teamcap.2395 View Post
How many hours have you guys worked during week 1?
They seem to be working on it almost all day every day during the week. If you want to check up on them, it's pretty easy....although it's Sunday today.
http://www.ustream.tv/channel/falcon-robotics-team-842
Unread 11-01-2009, 13:11
NickE's Avatar
NickE NickE is offline
_
Where's the cRIO?
Originally Posted by falconmaster View Post
Does the bumper perimeter have to be rectangular?
Originally Posted by 2009 FRC Manual Section 8.2
BUMPER PERIMETER – the polygon defined by the outer-most set of exterior vertices on the ROBOT (without the BUMPERS or Trailer Hitch attached) that are within the BUMPER ZONE. To determine the BUMPER PERIMETER, wrap a piece of string around the ROBOT at the level of the BUMPER ZONE - the string describes this polygon.
i.e. The bumper perimeter must be a convex polygon.
Unread 11-01-2009, 13:16
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Originally Posted by NickE View Post
Where do the cRio and Spikes go? i.e. The bumper perimeter must be a convex polygon.
That is interesting, where does it say that it must be convex?
That would settle the dispute......
Thanks for helping to vet us. We don't want to caught at a regional with a violation.
Faridodin "Fredi" Lajvardi KD7WKD
Unread 11-01-2009, 13:27
NickE's Avatar
_
It never explicitly says that it must be convex, but wrapping a string around a concave polygon will result with the string not following the entire perimeter of the polygon. If you wrap a string around this robot in the bumper zone, it will form a convex rectangle.
Unread 11-01-2009, 13:47
AKA: Ledge
definition per rules
We would have our string cross the opening of our bot. It does not say it has to make contact with the bumper zone everywhere. That is an assumption. Our polygon would be a rectangle, never the less we will cover the angles in from the corner with 6 inches of bumper. We think we are ok......I hope
Unread 11-01-2009, 13:49
NickE's Avatar
_
Would the bumpers be straight (parallel with back of bot) or angled (parallel with angled front sides of bot)?
Unread 11-01-2009, 13:52
AdamHeard's Avatar
Lead Mentor
I believe the intent is that bumpers must be on the bumper perimeter. You're taking a risky move, and should probably Q&A it.
Unread 11-01-2009, 14:04
GaryVoshol's Avatar
Cogito ergo arbitro
It's not just the intent, it's the rule:
Originally Posted by <R08>
L. The BUMPERS must be fixed to the BUMPER PERIMETER.
What needs to be answered in Q&A is if every side of your robot must have bumpers in order to satisfy the requirement that corners are protected.
(since 2004)
Unread 11-01-2009, 14:05
MrForbes's Avatar
AKA: Jim
That's the one that I haven't figured out for sure yet...and we're going to assume the answer is "yes". Which really limits the effectiveness of end loading narrow robots like Carmen, unfortunately.
Unread 11-01-2009, 16:16
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Another team member pointed this out to me today: the first thing to contact a flat vertical obstacle (aka the wall) must be your bumper. If you have one side completely uncovered, then the first thing to hit that vertical obstacle will be metal.
Unread 11-01-2009, 16:19
AKA: Ledge
angled
Unread 11-01-2009, 22:50
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
Angled "bumpers" would not pass inspection because technically they are not bumpers at all since they do not lie on the bumper perimeter according to the current set of definitions and both sides of the corner must be protected.
Unread 11-01-2009, 22:57
MrForbes's Avatar
AKA: Jim
Ahhh...here's that statement that seemed to me to be missing from the rules.
"2. As indicated in Rule <R08-I>, all exterior corners of the BUMPER PERIMETER must be protected by BUMPERS. Both "sides" of the corner must be protected."
from http://forums.usfirst.org/showthread.php?t=11159
Unread 11-01-2009, 23:56
AKA: Ledge
Ok Well according to Jim we are possible ok since we will have the bumpers over the corners and the first part to touch a wall will be the bumpers. Let keep or fingers crossed!
Unread 12-01-2009, 00:21
MrForbes's Avatar
AKA: Jim
The problem is the bumpers need to be on the bumper perimeter, which is the edge around the robot, and recessed parts of the frame are not the perimeter. So it looks to me like it's not legal. You'd have to put back the straight pieces across the front, but make them each 6" long, and cover them with 6" long bumpers. This will give a pretty small opening in the middle.
What a bummer, how vague the rules are this year on bumpers...they could have just come out and said what they wanted in the first place.
pic: Robot-Week1 Brad Voracek Extra Discussion 13 16-01-2009 11:44
pic: Team 842 in Hispanic Magazine falconmaster Extra Discussion 5 07-10-2008 19:28
pic: 1889 Team HAZE's frame (week1) Tytus Gerrish Extra Discussion 8 19-01-2007 02:23
pic: installed battery team 842 falconmaster Robot Showcase 11 04-02-2006 09:36
pic: Turret team 842 falconmaster Robot Showcase 3 01-02-2006 17:28
