Go to Post I predict the champion drive teams at each event of the 2011 season will consist of vertebrates. - Taylor [more]
Unread 24-06-2002, 00:44
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Counter loop
Posted by Eric at 2/12/2001 5:24 PM EST
Coach on team FEDS from RHS sponsored by Visteon.
If you want to time a motor out (say run it for 1 second and stop) and you wanted to do it more accuratly than simply counting loops (presumably bad data could thow this method off) what would the progam code look like? (I'm trying to get a handle on the delta_t kind of thing.)
#0047 (ChiefDelphi)
Re: Counter loop
Posted by Joe Ross at 2/12/2001 7:14 PM EST
Engineer on team #330, Beach Bot, from Hope Chapel Academy and NASA/JPL , J&F Machine, and Raytheon.
In Reply to: Counter loop
Posted by Eric on 2/12/2001 5:24 PM EST:
: If you want to time a motor out (say run it for 1 second and stop) and you wanted to do it more accuratly than simply counting loops (presumably bad data could thow this method off) what would the progam code look like? (I'm trying to get a handle on the delta_t kind of thing.)
delta_t is the number of data packets that you missed.
to be able to time things you should use the following idea:
counter = couter + 1 + delta_t
If delta_t is 0 then no data was lost and your program loop is less than 1/40th of a second. If delta_t is not zero, then you missed that many packets.
using this code, when the counter reaches 40 then 1 second has passed.
#0047 (ChiefDelphi)
Re: Counter loop
Posted by Rick Berube at 2/16/2001 12:16 AM EST
Engineer on team #121, Rhode Warriors, from Middletown H.S..
In Reply to: Re: Counter loop
Posted by Joe Ross on 2/12/2001 7:14 PM EST:
Actually, I observed the loop time between consecutive cylces vary between alternate cycles even with a stripped down version of the default program. We were transferring no more than 8-10 bytes (I don't remember exactly how many) between the player station & robot at the time. We measured 20-30 mS periods by simply toggling the state of the PWM signal at a relay channel every time through the main loop. We attached a scope to the channel and observed the period of PWM signal change from 20mS to 30 mS and continuously repeat. We also monitored delta_t during this time, using a debug statement to print a message whenever delta_t was not equal to zero, and never once saw the message!
I didn't dig into it any more, I just made note of it. I wonder if one were to monitor the serial stream between the receiver and RF modem, if they would see the same delay in the data stream or if the delay is incurred inside the receiver.
Rick
#0047 (ChiefDelphi)
FYI: re. OI/RC Communications
Posted by Nate Smith at 2/16/2001 11:07 AM EST
Other on team #66, Frostbite, from Willow Run High School and GM Powertrain.
Posted by Rick Berube on 2/16/2001 12:16 AM EST:
: Actually, I observed the loop time between consecutive cylces vary between alternate cycles even with a stripped down version of the default program. We were transferring no more than 8-10 bytes (I don't remember exactly how many) between the player station & robot at the time. We measured 20-30 mS periods by simply toggling the state of the PWM signal at a relay channel every time through the main loop. We attached a scope to the channel and observed the period of PWM signal change from 20mS to 30 mS and continuously repeat. We also monitored delta_t during this time, using a debug statement to print a message whenever delta_t was not equal to zero, and never once saw the message!
: I didn't dig into it any more, I just made note of it. I wonder if one were to monitor the serial stream between the receiver and RF modem, if they would see the same delay in the data stream or if the delay is incurred inside the receiver.
: Rick
One thing to keep in mind...even if you aren't getting them in your serin statement, or not using the inputs on the RC or OI, all of the data is still sent both ways...I know its 26 bytes(same as the dashboard output) for the data from RC to OI, but I dunno about the other way around...
Nate
[IMG] code is Off
Counter Strike Gadget470 Chit-Chat 20 11-07-2005 14:03
Actual execution time measurement Dan Technical Discussion 5 24-03-2003 11:36
How long is one stamp loop yangotang Programming 3 23-01-2003 20:36
Autonomous code PBoss Programming 7 14-01-2003 15:29
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
