Go to Post If you're in the Chairman's Award just to win the Chairman's Award, you're doing it for all the wrong reasons. The award is there as a goal to strive for, but it shouldn't be the reason why you conduct yourself and reach out to your community and beyond the way you do. - Lil' Lavery [more]
Unread 11-01-2009, 07:28
elbuo elbuo is offline
Teams #2884 and #1144
AKA: Yamil Asusta
FRC #1144 (Coquitron)
elbuo has a spectacular aura aboutelbuo has a spectacular aura aboutelbuo has a spectacular aura about
Driver Station Not Updating
Hey guys
Our driver station doesn't go out of OTB status so we can't upgrade the firmware. Can somebody explain me when the driver station is supposed to get out?
We did the wired benchtop test and everything worked out succesfully.
Unread 11-01-2009, 08:13
mahmosh's Avatar
mahmosh mahmosh is offline
FRC #1946
mahmosh is an unknown quantity at this point
Re: Driver Station Not Updating
did u use a flashdisk to update it ?? and if yes .. did u put the file that u need on it ??
Unread 11-01-2009, 08:17
mahmosh's Avatar
FRC #1946
i forget to tell you that ur flashdisk must not have auto run files ... rename it and then try again ....
if u need more help tell me ...
Unread 11-01-2009, 09:55
AKA: Yamil Asusta
We used a SanDisk and a U3.
And yes I downloaded the .bin file a renamed the file correctly.
I'll try with a different USB tomorrow and I'll report it to you.
Thanks
PS: I did remove the autorun in the U3 but the SanDisk I don't know how
Unread 12-01-2009, 07:52
AKA: Yamil Asusta
Guys, the OTB status must be present in the upgrade?
And do we need to do it before the wireless test?
Unread 12-01-2009, 16:23
Mr. E Mr. E is offline
Its physics or stamp collecting
FRC #1883
Mr. E is an unknown quantity at this point
is the file size 2.19 mb or 2.25 mb? I remember seeing 2250 in the documents somewhere but the file I keep downloading (without success to update the firmware) is 2.19
Unread 12-01-2009, 19:21
AKA: Yamil Asusta
It worked out great
Thanks
Unread 13-01-2009, 10:11
funggiss's Avatar
funggiss funggiss is offline
http://metrohomeschoolrobotics.o rg/
AKA: Trevor Stacy
FRC #1825 (MHR Cyborgs)
funggiss can only hope to improve
I can't get ours to update I'm using a dane elec flash drive that has no other files on but the firmware and it still won't update after I hold down select it goes to the start up menu and still says **otb** at the bottom
Unread 13-01-2009, 18:39
7-11number1 7-11number1 is offline
ROAR.
FRC #1711 (RAPTORS)
7-11number1 will become famous soon enough
We went through many USB thumbdrives until we realized that Windows was not showing us the true file extension and our file was named dsud_pkg.bin.bin.
The solution is to go into the window file manager (explorer) and Tools->Folder Options->VIEW TAB-> and UNCHECK "Hide extensions for known file types."
You will probably see a double file extension and this will solve your problem.
AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!!!!
2nd Driver Station bcharbonneau General Forum 2 09-01-2009 14:19
Driver Station not allowing team number change Bryan Herbst FRC Control System 2 04-01-2009 12:26
Help with updating firmware on Driver Station urg8rb8 FRC Control System 3 28-12-2008 02:53
Driver Station Setup?? Team 1708 Dave Programming 9 19-12-2008 23:09
Serial Driver and 2K6 Encoder Driver Not compatible Tom Bottiglieri Programming 6 12-02-2006 01:11
